Wonderful...and the dayton sub?
G gus6464 Audioholic Samurai Jul 18, 2008 #42 I would also recommend he get a serial to usb adapter like this one so he can use the Behringer software to set up the DCX. http://www.newegg.com/Product/Product.aspx?Item=N82E16822998007
G gus6464 Audioholic Samurai Jul 18, 2008 #43 eggyhustles said: Wonderful...and the dayton sub? Click to expand... If he decides to get the sub just connect it with XLR cable to output 3 on the DCX. The huge DCX manual will have diagrams for all the different connection options as far as speakers go.
E eggyhustles Audioholic Intern Jul 18, 2008 #44 Okay..once again..thanks alot you've been a huge help
G gus6464 Audioholic Samurai Jul 18, 2008 #45 eggyhustles said: Okay..once again..thanks alot you've been a huge help Click to expand... No problem. Also here is a link on how to setup the calibrate the mic and get the DCX up and running with REW. http://www.hometheatershack.com/roomeq/ You will connect the ECM8000 to the 0404 using xlr cable to any of the two mic inputs. But that link will have all the info you need on how to get everything setup properly so he can start mixing.
