Receiver doesn’t decode DTS
G
Giel
Whilst Googling I passed by this forum. I have a problem that I can’t seem to figure out on my own. I recently bought a NetGear EVA9100 media player to stream HD content from my PC to my television. The 9100 is wired by a HDMI cable to my television and an optical cable to my Denon AVR-1602 receiver.
The AVR-1602 does have DTS certification, but I don’t get any sound from any of my movies with DTS. I tried many combinations getting the sound to work, but without success. I do get sound from movies without DTS.
Does someone know the correct set-up or if my receiver is just too old and broke down on the DTS decoding?
Thanks a lot.
Nomo
Nomo
I'm guessing that the TV is the weak link.
It's most likely not capable of outputting a DTS signal.
Try hooking the Netgear directly to the receiver, and then to the TV. Let the receiver do the decoding.
G
Giel
I have the NetGear connected to the TV by HDMI (for the picture)
The optical cable (for the sound) is plugged directly into the receiver
anamorphic96
anamorphic96
Is the content encoded with a DTS soundtrack ?
If it does not have a DTS track then there is nothing you can do except play it back with what its encoded with. DTS just can't be chosen on the receiver. There needs to be a DTS track to start with that is encoded on the media.
G
Giel
When I go to the "info"-section on the NetGear EVA. The video's that don't have sound say "Audio: English (DTS, 48kHz, 6ch)".
G
Giel
Problem solved!
Apparently some of the audio settings on the EVA9100 where still set to "stereo" in stead of "passthrough". Changed it, and eureka!
Thanks all.
