Receiver and amp pick for full 7.2.4 Atmos setup
agarwalro
agarwalro
Which AVR would you consider high end? For me that would be the AVR-x7200wa, RX-A3070, MRX-1120 and some Euro models such as Arcam's top models.
AVR-x4300H, X6300H, SR7011 etc would be mid range.
If using launch MSRP alone, I consider the bands, < $1500, $1500-$2500 and $2500+.
Yamaha and Denon hit the AVR price/features sweet spot at any tier.
Marantz slightly less so in mid to low tiers.
Anthem not at all.
The best deal can be had when picking up a previous gen AVR on closeout pricing, like the 4300H currently for $800. This may not apply every generation, like when HDMI 1.3/HDCP 2.2 got introduced. So, I have an AVR that's completely satisfactory in audio processing, but, lags on the video side.
Pogre
Pogre
If you really need the additional power of a 200W amp, then the Monolith 5x200 is a simple solution. If you don't need that 1 to 2 dB more output then just add one of those low cost 2x75W amp and you won't know the difference.
More power only makes a difference if the extra power is actually used.
Or get the 7. Best bang for buck and there's no such thing as too many channels! :D
Perhaps just use a pair of active speakers like JBL 305s....
E
Epetti
That would make sense from a customer perspective, not for D&M.
The fully assignable amps are in the receivers a step or two up.
Old thread but new info for anyone interested. I don't know if it came with a firmware update or it's always been there, but with the Denon 4300 and an 11.1 channel setup you can choose either Height 2 or Front to go to pre-amp. So you can just use a three channel amp for LCR and let the receiver do all of your surrounds.
