Reasonably priced full range speaker
TankTop5
Think I’m about to score a pair of Klipsch Forte’s for $250. Not cosmetically great but seller said they sound perfect, will listen before I buy. Anything I should look for or listen for?
Russdawg1
Original forte’s? Check for the cabinets being sealed decently and the crossover being intact.
TankTop5
Thanks, I was thinking about the boxes integrity but not the crossover. They also have Klipsch KG 4.2’s for $225 (I think a touch high) and Klipsch Chorus II’s for $750.
Russdawg1
I have the Klipsch 4.2’s. They are definitely worth $225 after some easy caulking and adding in some extra foam/poly fill.
The horns they use in the older models don’t resemble anything of the newer ones. Not harsh, imaging is beyond phenomenal and they play like new even after 20 years.
I had a diaphragm fail on me two weeks ago. Replaced it, plays just as good and it was a $16 replacement.
The bass is really tight, chest kick is amazing. I would really consider those 4.2’s. I did get mine for $110 though.
KEW
KEW
Did you get the replacement diaphragm through Klipsch or have to do some research to find a suitable replacement?
Russdawg1
Research for suitable.
I mean I wasn’t expecting anything great, after all I got them for $110, but I got the replacement diaphragm for a K85K Horn (written on the back of the magnet when I opened it up) and it played like new. I was expecting some tonality difference and to have to order a second replacement to match it but it was spot on, to my ears at least. An audiophile may discern it.
TankTop5
Sounds like either way I will leave with a great set of speakers.
