lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Nov 10, 2020 #41 Varies per system for me but generally my xovers are in the 80-120 range but don't distinguish between music vs movie sources.
G GregKeyesPe Junior Audioholic Mar 3, 2020 54 0 6 41 Nov 10, 2020 #42 Think hard reset work! Do you think having my input level boosted to +6 bad on my Marantz? I do think it’s low volume when you’re streaming Bluetooth! thank y’all so much
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Nov 10, 2020 #43 I wouldn't worry about 6+ as much as maxing it out....(it goes to 12, right?). Will you increase the volume on your phone to max when streaming for the +6 setting?
G GregKeyesPe Junior Audioholic Mar 3, 2020 54 0 6 41 Nov 10, 2020 #44 lovinthehd said: I wouldn't worry about 6+ as much as maxing it out....(it goes to 12, right?). Will you increase the volume on your phone to max when streaming for the +6 setting? Click to expand... Yeah it goes to 12. This how I connect my phone to the AVR under Bluetooth then I stream tidal from that way.
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Nov 10, 2020 #45 GregKeyesPe said: Yeah it goes to 12. This how I connect my phone to the AVR under Bluetooth then I stream tidal from that way. Click to expand... Whatever still sounds good in the end counts. Why not just go for higher fidelity wifi when you stream instead of bluetooth?
KEW Audioholic Overlord Jul 12, 2009 11,572 0 113 Jowjah Nov 10, 2020 #46 Do you have a DVD player from another room you could hook up temporarily for troubleshooting purposes? That way you can check behavior using the standardized movie SPL. Last edited: Nov 11, 2020 Reactions: lovinthehd
T Tachead7075 Audioholic Jul 1, 2020 190 0 16 45 Nov 11, 2020 #47 It sounds like a Bluetooth issue to me as I had the same problem a while back with one of my Bluetooth speakers. Try going in your phones bluetooth settings and forgetting the device you are streaming to, then rescan and add it again. Be careful as it may add a large boost in gain.
G GregKeyesPe Junior Audioholic Mar 3, 2020 54 0 6 41 Nov 13, 2020 #48 Do y’all use the channel adjust level option? Does it use the power from the master volume?
G GregKeyesPe Junior Audioholic Mar 3, 2020 54 0 6 41 Nov 13, 2020 #49 lovinthehd said: Whatever still sounds good in the end counts. Why not just go for higher fidelity wifi when you stream instead of bluetooth? Click to expand... what do you mean exactly? Sorry don’t mean be stupid
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Nov 13, 2020 #50 Bluetooth, while having got much better over the years, has limitations altho some of the latest versions are pretty good. Much streaming can be done outside of bluetooth, by using networks both local and otherwise....
G GregKeyesPe Junior Audioholic Mar 3, 2020 54 0 6 41 Nov 13, 2020 #51 lovinthehd said: Bluetooth, while having got much better over the years, has limitations altho some of the latest versions are pretty good. Much streaming can be done outside of bluetooth, by using networks both local and otherwise.... Click to expand... It’s something with the Bluetooth because when I change the input to CD for my dragonfly! I have insane volume at -20
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Nov 13, 2020 #52 GregKeyesPe said: It’s something with the Bluetooth because when I change the input to CD for my dragonfly! I have insane volume at -20 Click to expand... Input levels vary. Some have controls. YMMV.
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Nov 22, 2020 #54 Your Mileage May Vary
