Ok not sure how to describe this category of speakers but I was wondering whats plasma-matching minimilistic speakers (the long thin type that run below and on either side of the plasma screen) are out there that will provide a high quality audio environment for movies and music
- Maybe 75% video and 25% audio.
- Reasonable budget (less than $1500 maybe $2000 for a 7.1 set).
- Connect to a new Yamaha RX-V1500.
- Ok to use a 10" or 12" sub
- Room is 19' x 19' with 10' ceilings
- Dont need to kill the neighbors or the newborn with the volume level.
I noticed the KEF KHT5005 and 9000ACE but suspect both are too expensive.
I know these will not provide the same depth and volume as the Axiom, Aperion, or Mordaunt systems I am also considering but need a wife friendly option that looks good next to the new plasma TV. I am posting a seperate question about the RBH, KEF, and HSU Research mini-satellite options as well as the Axiom, Aperion, or Mordaunt systems.
Thanks for any help.
-Rob
