Problem with setting up surround sound system with an old AV receiver
  • Thread starter Thread starter JLorenzo
Here are more of the pictures of the speakers/subwoofer!
Frontal speakers:
(all the same speaker, front/side-front/side-back view)
Some details:
Height: 1.33cm's
Width: 18 - 24cm's (depending on where I measure)
Depth: 32cm's
Height of Grill: 73cm's
Subwoofer:
(Front/Side/Back view)
Bottom of subwoofer (between the gap) - Front
Bottom of subwoofer (between the gap) -Back
Some details:
Height:47cm's
Width: 35-38cm's (depending on where I measure)
Depth: 42cm's
I also got some of the central speaker, and the 2 speakers in the back (I think those are called the surround speakers?):
Center speaker:
Speakers in the back:
(also all pictures from the same speaker)
Hey guys, again thanks for all the help!
I got the new AVR and can connect it with my phone trough aux/bluetooth and all speakers work now :)
TV also works with hdmi!
Only thing I can't get to work, is the yamaha app (even tho it shows my avr as supported).
It shows a few requirements:
But I can't find both "Network standby" or "Wifi/Lan/Network" settings on the avr (either trough remote or the avr itself)
I also searched in the manual but did not find anything about it.
But I guess I do not really need the app, would just a little quality of life upgrade.
Just as a little sidenote (thought it would be fun to share)
When I at first connected my TV with the AVR, it had a song already playing.
For some reason the AVR instantly went up to 100% and my room almost blew up, my ears are stull buzzing from 30 minutes ago. o_O
I guess I learned quick (and the hard way) because every time I connect something for the first time now, I pause the music and check the sound first. ;)
Unfortunately, that model does not support a network connection for use with the Yamaha Controller or MusicCast apps.
