ParadigmDawg
ParadigmDawg
Hey guys, I need one of these cords, is it something that I can just go buy or find online? It is the cord that goes to a second part of another cord (the one with a power looking thingie on it) I know this is confusing but here is a picture.
mudrummer99
Check Radio Shack, failing that you should have no problem finding one of those online, maybe one of the other posters will have the technical name for it because I sure don't. Hope that helps (very little I'm sure)
Mike
ParadigmDawg
ParadigmDawg
Ok, cool, it seems to be a common cord so I will just check the Rat Shack.
Thanks!
jostenmeat
GG, I was very recently on the hunt for some, and I found a couple of links, and then a couple more were given to me at a different forum:
http://www.iec.net/Browse05/LM1303.html
use search function to fond cords:
http://www.tigerdirect.com/indexus.asp?SRCCODE=WEBGOOTD&CMP=KNC-GOOGL
I ordered here before I received info on the above, however, they still haven't arrived yet. Monoprice has thoroughly spoiled me as they arrive the very next day to me in CA:
http://www.cablewholesale.com/index.php?section=Power Product&body=Power Cords&gclid=CMHQpc6C3pECFQKRgwodZAiPfQ
One more:
http://www.cablestogo.com/product_list.asp?cat_id=914&cm_mmc=AdWords-_-07-ALWAYS+ON-_-computer+power+cord_890291901-_-computer+power+cord_Exact_|-|100000000000000133295&gclid=CKDDsr6C3pECFQc-gwodRnZyeQ
and Im sure Rat Shack is fine. I was looking for particular lengths, one very long one as well....
