Unregistered said:
If a piece of equipment's power consumption is stated in amps how do you
convert to watts and vice versa?
I've been looking at different avr's, for example, elite vsx-59txi 725watts, rz-z9 1000watts(1200VA), avr-5803 12.1amps, hk avr-630 1000watts.
How come an avr-630 absorbs more power than a vsx-59txi
This might help:
"This Receiver is more powerful than the other one.
The power game that many receiver manufacturers play can be most misleading. There are so many multi thousand dollar flagship receivers on the market these days that claim over 100 watts a channel times 5 or even 7 channels. Let think about this for the moment and take a look at one of the top receivers on the market, the Denon AVR 5800.
The Denon AVR 5800 claims 170 watts/ch for all 7 channels. If this implies continuous power for all channels driven, than the receiver must consume (170*7) / 0.75 (efficiency factor of class AB) = 1586 watts for the power section alone. This is an impressive claim considering that the common wall socket can only produce 120V*15amps = 1800 watts. This means you must plug this bad boy into its own dedicated line to achieve these power levels, assuming the power supply is up for the task (1200VA power supply featured in this receiver, cannot).
The fuse rating on this receiver is 11 amps. It is common practice in engineering to derate a fuse to 75% of its maximum sustained current ratings. Thus the Receiver should not consume more than 0.75*11 amps = 8.25 amps. That being the case, the maximum power consumption of this receiver cannot exceed 120V*8.25A = 990watts. Since this receiver has one common power supply, it must share with the processor, preamp, etc. Lets assume the processor/preamp consumes 100 watts, this leaves 990 - 100 - 890 watts available for the power section. Take 890*0.75 (efficiency factor) = 667 watts.
667 watts divided into 7 channels equals a whopping 95 watts /ch which is almost half of the specified power ratings! If we don't consider derating the fuse, than the total power available would be 120V*11A = 1320 watts - 100 watts = 1220 *0.75 = 915 / 7ch = 130 watts / ch which are still below the 170 watt/ch ratings.
So you are probably wondering how Denon can get away with this? The answer is; they never claimed the receiver could deliver 170watt/ch with all channels driven. They rate power for each channel driven instead. Again, the average consumer does not know this and thus chooses this receiver based on big power ratings. The point of this exercise to is bring awareness to consumers on how power is rated so that when they compare Receivers/Amps from competing manufacturers, they know if they are making an apples to apples comparison with respect to the power game.
When judging power, look for the following:
Continuous Power / Channel from 20Hz to 20KHz into 8/4 ohm loads
with all channels driven."
Straight from the AH website.
