Post Your Home Theater Here!
mischa316
On the left side is my EQ, HD-A1, & Panasonic 5.1 Surround w/ 5 disk dvd player, The tv is a Philips 42" Plasma w/ Ambilight, then on the Right is my Cable Box & PS3!!
Mischa.
Seth=L
Seth=L
We can see your hobby is focused on the video part. Blu-ray, HD DVD, Plasma display.:)
mfabien
Made a change in the HT
Following post # 40, in this thread, I just added new leather recliners to view HD and to listen to music:
dukedallas
Memone Family Theater Project
Project build begin date 11/03/2003 - Opening Night 1/26/2007
I began thinking of my theater build project years before I was even was married or owned a home. Mentioning this, I began to purchase High-End speakers and a few components here and there knowing I would use them in the future in my theater. I started with speakers because the technology doesn't drastically change like electronics do every other year in general. Then a power cleaner (Monster Power 5000)
So my wife and I found our home, only the foundation had been poured, right away I was eyeing up the basement as my domain. :)
So the house was built, and the wife had no interest in the basement or what i did with it, as long as it was useable.
Well here and there I would purchase a piece of equipment as our budget allowed, finally the first steps of the build which I was looking forward to.
I purchased some home design software and created the basement design. I wanted 3 rooms, a childrens playroom, a gameroom, and a theater!
the software was a great help in the early stages becasue I was able to put dimensions of the rooms in and do virtual walk throughs, really cool!!! It inspired me even more.
In my research I ran into a great webiste where a really nice guy designed his theater and had many of the same ideas which I had thought of all along such as stadium bi-level seating. His website was awesome!!! It gave step by step design and build ideas many of which I incorporated and modified to suit my design.
So finally it was time to prep the bare cement walls, even though my basement is bone dry I wanted to know to feel secure knowing I would not have to deal with any moisture problems. I painted all the walls with killz cement sealer bought by the gallon at home depot. Once the walls were bare cement walls were preped it was time for the studs and framing and sheetrock etc..... This part of the project took me about 1.5 years, I did everything myself with help of various friends in the trades which really saved me in labor costs. In fact, the only items which I did not do myself was the electrical connections (Licensed electrician) and rugs. Everything else was done basically 8pm to midnight for about 1.5 years. Now mind you there were times where I was just burned out so I would take a few weeks off just to get away or for budgetary reasons. If you plan on taking on a project this size here are some important lessons I learned.
1) Plan, Plan plan.... Meaning, think placement of outlets wire runs, heating and cooling systems just to name a few....
2) If you find yourself getting tired, take a break from the project to revitalize yourself
3) Dont cut corners, redoing work is no fun.
4) Plan plan plan :)
I wanted the theater to be as sound proof as possible, so I took steps to insure sound stayed in the room as much as possible. I lined the studs in the Theater room with pink thin sponge insulation using glue. This was barrier 1, next sound barrier ... I lined the bottom half of the room with carpet which further dampened the echoing effects and helped sound proofing, next I purchased 12inchX12inch acoustic foam panels and lined behind the speakers and the back wall. Finally I added a drop ceiling. All these steps make the room relatively sound proof, If a movie is on in the theater it isnt an annoyance through the rest of the house..which is great!!!!
Well attached are the pictures of the build and final product. Feel free to email me or contact me if you have any questions about equipment, design ideas or any other things I can help out with for your build. I could write a book just listing all the equipment and specifics so I will just leave it up to the reader to ask specific questions. Anyway enjoy and good luck!!!
Shop around on the internet look for bargins, you can really find some neat stuff!!!
I've had questions about the screen...well it was a "do it yourself project" bought the fabric on eBay approx $80 1.3 gain 96" X 54" built a fame for about $60 worth of materials. If any of you have been shopping for screens your looking at $600+ starting price for fixed frame screens.
SAFETY:
1 thing really never mentioned in any of the posts I have read is safety. For those people building their theaters in basements keep the following in mind. Have clearly marked EXITS in case of fire, and Extinguishers!!! Install Carbon Monoxide Detectors ($30) in key areas. Most of us building in basements share the basement with our furnace/oil burner MAKE SURE YOU BUY A CARBON MONOXIDE DETECTOR!!! Have a exit escape plan/strategy, don't be caught off guard. You and your families lives are'nt worth a movie!
DATA:
3 Carbon Monoxide Detectors - 4 smoke detectors - 2 Escape Ladders - 3 extinguishers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Room Size: Theater = W12.5 ft X L22ft X H8.5ft
Consession = W12.5 ft X L17ft x H8.5ft
Estimated build cost Actual = $25,000 with 95% DIY
Retail = $60,000 - $75,000 easy
All Klipsch Speakers (7.1 Surround) SVS Subwoofer
All compunents run off of dedicated HTPC in association with cinemar control software. Including lighting effects.
F
feffpig
Ok, this thread one caught my eye. I do happen to be an expert on this stuff...I'm a retired CIH (look it up) and spent YEARS dealing with asbestos and fiberglass.
The fibers not only act differently on the body, they look completely different under a microscope, they break down differently (making asbestos incredibly dangerous when airborne), they go and stay airborne at different sizes and stay entrained for different lenths of time, and as a result having completely different sets of regulations addressing their safety & handling.
Asbestos is very bad for the body in almost all it's forms (there are numerous types of asbestos, some are worse than others)...but it is GREAT material industrially, almost none better.
Fiberglass is a good material industrially, but is not in the same ballpark as asbestos where health is concerned.
That said, fiberglass is classed as a serious household nuisance dust (by inhalation and skin, obviously), especially if you use it in the home interior, like in sound panels, unless you encase it in a very fine mesh fabric of some sort. I should say that among the experts, there has been debate raging for years (about 30), but studies I've read, which ceased about 10 yrs ago) fall on the side of fiberglass being more a nuisance dust...but there still is potential there for eventual serious harm discovery.
Mineral Wool is more suspect health-wise than fiberglass, and even more precautions are needed...best stay away from using that...more like asbestos in handling.
I solved that irritant and fiberglass dust issue in my HT by using a material made up north (Illinois, I think), of shredded blue jeans, treated with borax (near harmless to humans) to deter roaches and mold. It also happens to work GREAT as an acoustic damping agent. My incredibly 'live' room (I could originally snap my fingers and hear the snap echo 2-3 times) now sounds quite hushed when you walk in, and I haven't even hung wall panels yet. I only treated the front wall on either side of the screen, and covered it with a simple 1"x2" wooden frame covered in black cloth (cheap stuff). It works GREAT.
I'll be constructing 4 wall panels of the same material,
using 1"x3" wooden frames, then hanging them in the primary reflection zones...it'll be quite 'dead' then.
No fiberglass, no mineral wool, no asbestos (you'd have to be insane to go there...besides that it's been illegal since the early 70's).
My 3 cents, fwiw.
bigbangtheory
Components:
ATI 8500.1 Pre/Pro
ATI 3006 300 x 6 channel amp.
ATI 3004 300 x4 channel amp
Samsung HD 931 DVD player
Sony DVPCX777ES multi-disc DVD player
Monster HTS 3600 Line Conditioner
InFocus SP 7205 projector
Da-Lite High Contrast Cinema Contour Cinema Vision 54x96 screen
Scientific Atlanta HD receiver from Adelphia cable
Speakers:
JAMO D870 Front Left and Right
JAMO D8CEN Center
JAMO D8SUR 2 Surround, 2 Rear
Seating:
6 Berkline Theatre Recliners
4 barstools for late-arrivals
Acoustics:
Auralex paneling for walls, ceiling, and bass traps
Refrigerator:
Stocked with plenty of refreshing beer
Anyone near Atlanta ready to partay?
Sic 'em Dawgs! Woof Woof Woof!
I think I can speak on behalf of everyone else when I say, "that just isn't fair!"
Congrats on a fine fine system!!
benolium
Thanks
Clean as possible. That's the whole idea. I think that I'm outgrowing these Bic's. I have a bad case of the wants:D:D:D McIntosh, B&W....I could go on forever. Thanks for the compliments!!
O
ofpiste
Finally done!!!
Although you are really never done.
Built this myself from a empty room that the previous owners used as a small gym.
My equipment list includes;
Rotel Ingegrated Video Amp
Rotel DVD
B & W 7 series speakers all around
Paradigm 12" sub
DeLite Screen
Panasonic AU900
Monster clean power
Lutron lighting system.
Theater seating by Stressless
Carpet is Silver Screen
This has been quite the journey..my first theater was a 10 person affair, but in loud colors (red suede seating, bright carpet, etc). I had a Sanyo PLV 60 with a Stewart Firehawk, which i wish i would have purchased again. Delite is nice, but not the Firehawk brightness....
I still have to do:
cloud scene and hand low voltage airplane and balloon light.
Some theater art, maybe upgrage to a 1080 projector.
mike08
how do post your pics
Can u tell me the steps to put your pics on here because i am a new member. I am now allowed to add attachments to my threads and want to show off my ht to all members.Maybe get some more advice on sp placement and so on. thanks
croseiv
croseiv
Get an account with photobucket. Upload your photos there and then paste the link in your post here.
Cruise Missile
Cruise Missile
Well, Here's my little system.
We currently rent, the wife is in the USAF, so we move every few years.
I am really looking forward to living in one place for a while. Then I'll finally go dedicated...
  • Like
Reactions: 3db
gweedo
gweedo
just seeing if I can post pics, if it works here is my apartment setup, next post will be my house setup..:rolleyes:
  • Like
Reactions: 3db
Mr.M-500t
Mr.M-500t
Here is an older picture of my system. It's changing all the time. I'll take a new picture later and post it.
  • Like
Reactions: 3db
Seth=L
Seth=L
WOW, good old Klipsch (those are the ones with the passive bass radiator correct?), Paradigm, BIC (Acoustec), Martin Logan, and a crap ton of Carver gear. You must love Carver.:D
Mr.M-500t
Mr.M-500t
Yes I have a boat load of Carver Gear. Been in love with Carver since the mid eighties. I'll be posting a picture of the latest set-up soon.
