Please help me find replacement knobs for Elan Whole House Audio Room Vol Control
I know different brand dimmers use the "D' style knob.
I'll look some up, and let you know.
Rick
There you go. I know those knobs are on all kinds of devices. He would be out much if he has to buy one of those dimmers to replace every broken knob.
I have never found those knobs though as a standalone item.
Well done Rickster.
slobizman
slobizman
Darn! I took one of the unis out of the wall and it is a fancy digital unit, so it's proprietary and I cannot replace it with a standard one.
Well done Rickster.
Go ahead and get the knobs Rickster found for you. It took a good electrician to know where to look.
rickster had some good links. I found this, hope it helps.
http://www.thefind.com/hardware/browse-leviton-knobs
I couldn't find any site that actually showed the shaft style.
It won't matter if the knob does not have a flat for the shaft. If the knob is loose, he can make a shim out of plastic or wood. If the hole is snug, he can carefully drill it out and then make a shim. I would not use an electric drill though, but hand drill. This will not be a problem with the minimum of ingenuity.
tcs05
control knobs
I am having EXACTLY the same problem. I went on the internet to try to find these knobs and came across your post. I have contacted my installer and Elan and have gotten no help. Have you had any luck? TCS
Adam
Adam
Welcome to the forum, TCS!
The OP only stayed around for a day and then left. His last activity was after TLS' post on getting the knobs that Rick suggested (although I can't say if he read that post). So, I don't think the OP is going to come back and let us know what ended up working.
There were a number of good suggestions in this thread, though. Just let us know if you need any more help after reading through it and checking out some of the products that were suggested.
