Triple shoot-out (Pioneer-Yamaha-Denon), and last but not least, Onkyo.
How's it going Bob,
I looked into the features of the v662 & 6150 Yamaha's and the main issues I have is the lack of HDMI inputs, currently I'm running 3 HDMI sources (Cable box, PS3, Dvd upconverter) and apparently those two models only offer 2 inputs when the new models I've purchased offer 4 inputs, which is pretty good and gives me additional options, the Denon AVR 789 looks good even though it has 3 HDMI inputs, but is it really as difficult to set up as the reviews suggest?
Hi Justin, thanks, I'm going great (well, I think, last time I check anyway).
Ok then, so you'd better look at one that has at least three HDMI inputs, or even four, for possible addition of another source with HDMI connection.
And as for the Denon receivers with Audyssey Automatic Room EQ calibration, it's not difficult, but it does take more time. Some people don't like that, they rather have a simple system that is quick and don't demand too much effort. But I personally like more Audyssey for it's general overall performance. But that's just me (and few other people too).
So, I'll say, NO, it's not as difficult as some people would like to make you believe. But you do have to follow the instructions, like any other system, that's all. The Denon AVR-789 (3 HDMI inputs) is a very nice receiver, that few people prefer over the similar Pioneer VSX-1019AH-K, that's all, so I just mentioned it to you so that you know your other good option.
That's my job to let people know, just like you.
Hi,
Definitely go w/ the Pioneer. But I would suggest getting the VSX-919 instead because the only difference between the 919 and 1019 is that the 1019 offers second room audio. If you need that then go for it, otherwise save a few bucks and get vsx-919 instead. Pioneer receivers are one of the top ones out there and with the new 9 series line up, they offer the best bang for you bucks. Pioneers don't typically run hot but as with any equipment, proper ventilation is necessary. 2.5" space above the receiver is too small of a gap. You should give it atleast a 4" gap because you don't the the heat to be circulating around the receiver. Maybe thats why some people are having heat issues. I will be getting the vsx-919 soon for my home theater set up. Hope this helpled.
I think that H/K might have a good point here, if you can save yourself a couple hundred box, it's not bad. And it only has one HDMI input less than the 1019, which with three of them, you're still covered (for now).
But then, I would still go with the Denon AVR-789.
But again, that's just me (and a few others too).
Hey whats up H/K Thunder
Thanks for you input, I have indeed looked into the vsx919 model, and it's about $200 less then the 1019, besides the multi-room funtion, and apparently it has 3 HDMI inputs (4inputs on the 1019) Are there any other differences between the two models? no sound differences or anything? as for my heat concerns, my TV stand is wide open, the receiver has nothing blocking it's ventilation, it's completely wide open on all angles, except the top..which has a somewhat thin glass shelf that has the center speaker sitting on top, that's my only worry, after several hours on, the glass gets pretty warm, and the receiver felt pretty hot, (although the display model at best buy, which has no ventilation issues, did run just as hot) I'm curious if there's a difference in heat output between the 919 &1019..
There wouldn't be any sound difference between the 919 and the 1019.
The (4)* Pioneer VSX-1019AH-K would only be slightly more powerfull, but not much.
From what I gathered, some people still prefer the 1019 over the 919,
but what do I know myself?
If you found the 1019 is running too hot for your own taste, I would simply discard it. I don't have a clue as for how hot the 919 is. You'll have to check that for yourself.
Hey Justin, you did not tell me how much is the (2)* Denon AVR-789 (canadian dollars). I would appreciate if you do so, as well the (5)* Pioneer VSX-919.
Also if you can get the price of the (3)* Yamaha HTR-6260, that'll be great too.
And finally, I guess you're not interested by the (1)* Onkyo TX-SR606 (4 HDMI inputs), a great receiver, perhaps the best of this bunch, might run a littlte too hot for your taste, but you'd be passing on a very good receiver, which would be your lost. Check the price anyway (London Drugs).
* You probably noticed the numbers in brackets followed by an asterisk.
That's how I ranked them in order from 1 to 5, as the Onkyo TX-SR606 being my first choice, the Denon AVR-789 being my second one, ... and last (5) the Pioneer VSX-919.
I'm done. Now it's all up to you do do what you have to do.
Good luck, good night and good day.
Let me know of your final decision.
Regards,
Bob
