U
Urr@za
Bought this AMP almost new. How do I configurate the amp to have all speakers work? I can't make them all work at the same time. i'm using all 7 speaker connections. can someone help me out?
It's an avr rather than amp only. First I'd run a full reset of a used avr to clear out all settings and start fresh. Source/sound mode used can dictate what speakers are in use, you'll have to expand on your settings/setup....the Pioneer manual probably will answer all your questions, tho it may take some time to go thru....
U
Urr@za
thanks for your answer, I've already done that. but still can't get all the speakers to work. when I run the sound test they all sound.
we do not have the microphone that comes with the AVR, hope that's not a must have.
If the setup sounds all work then it just points to what sound mode you're using if you want to use a particular grouping of speakers. While you don't need to use a setup mic, it could be good as MCACC isn't a bad way to go IME. Be more specific as to what source/settings you're using. Manual setup would use at least an spl meter, tho (even a phone app could possibly be sufficient).
