seesara said:
I'm close to buying the receiver and speakers recommended in the $1,000 Audio System buying guide, but in the "useful features" section for the receiver, it lists "lacks phono input." I can't find mention of this anywhere else. Does this mean I can't connect my record player to this receiver? The alternate in the recommended system is the Yamaha HTR-5840...can I connect my record player to that receiver?
MDS said:
You can't connect the turntable directly, but all is not lost. You can buy a phono pre-amp. The turntable connects to the phono pre-amp and then the pre-amp connects to the receiver using any of the line level inputs (tape, cd, aux, etc).
Alternatively, you can buy a turntable that has a built-in phono pre-amp.
Most receivers at this price point do not have phono input. It requires the pre-amp with RIAA equalization which adds to the cost and since most people in today's world don't need them, the manufacturers have eliminated them from the entry level receivers. I think there is one Harmon Kardon unit around this price point that has it, but I can't rmember the model, and I don't know anything about its other features.
But MDS is right, it's pretty simple to solve the problem with a relatively inexpensive phono pre-amp. At one point I was considering both the Pioneer 815 and 1015 and since I have an older turntable without a pre-amp I was looking at options to be able to play my "beloved vinyl" collection.
(Eventually I decided on the Pioneer VSX-72 which has the phono input, so that solved the problem, but it's a more expensive reciever.)
Anyway -- in the process of working thorugh all this I came across a web site that offers a variety of pre-amps, switches, etc. so I thought I would pass it along FWIW.
http://www.audioreplay.net/. This isn't an endorsment, I have no idea if the are any good, but it's a source to check out. They have a great link at the top of the page
'So, you want to know, "what's a phono preamp, and why do I need one?" we're glad you asked...' I'm sure other forum member have sources of phono pre-amps they can recommend based on experience.
Also as MDS says -- if you're in the market for a new turntable -- just get one with a built-in pre-amp -- end of problem. Hope this helps.
