MacManNM said:
What exactly did you measure and what did you measure it with? Can you post your data? I was thinking about using this unit in my 2nd system, so I'd be very interested in your results. The chip looks to have a cutoff above 20KHz, and any noise in it would be introduced by the PS. Thanks.
I am sorry I dont have the measured data stored anywhere.
Most opamps have very good frequency range, doesnt mean they can reproduce those frequencies with good accuracy.
Noise is a non issue since most of these opamps have uV(microvolt) noise levels and the signal is already in the few mV(millivolt) and above range.
NJM4558 is the equivalent of LM1458, which is the dual version of LM741 opamp. 741 and equivalents have slew rates (0.5v/microSec) that cant reproduce 20Khz faithfully.
4558 was improved a bit to increase the slew rate to 1v/microSec, so it does claim to work in the audio band, just good enough for 20-20Khz, but the sound quality has
no depth,
nor clarity
Pioneer uses some opamps in the chain like uPC4570 from NEC, which is equivalent of LM833, this is a very good opamp.
But once the source is degraded in the chain(multi-ch input), it cant be brought back to high quality sound.
Digital inputs sound better because the opamps after the DACs used are not 4558 in most Pioneers.
I see that you use Yamaha 5790, this has high quality opamps in the audio chain like NJM2068. These opamps are equivalent to LM833 too
I have the same reciever.
Also, most Pioneer uses chip power amps made by Sanyo, depending on the version of the chip these have 0.1% to 1%THD(lower quality version) or 0.08%THD(higher quality version)
These chips arent that bad, but the lower quality, flat sound comes from the pre amp sections.
Yamaha, Onkyo etc.. use discrete power amps that are designed well.
Compare the THD numbers for Yamaha and Pioneer receivers, you will know what I mean.
I am sure in the end, you might like the Pioneer, but it wont be as good sounding as an entry level Yamaha or Onkyo, just as an example
Happy shopping
