PC Speaker system hooked to TV
avatar57
I have an Altec Lansing PC speaker system with subwoofer that works great with my Laptop. I recently bought a LG 32" LCD TV which has a Headphone socket.
When I connected my PC speaker system to the Headphone socket, the TV sound output was pathetic and probably did not work with the subwoofer.
Is there a compatibility issue here? I do want to use the existing system because the sound is just awesome and as good as a Home theater system.
Thanks
I
ichigo
TV sound in general is pathetic, the source is just...bad. No comment on the pc system.
just-some-guy
just-some-guy
connect them to the RCA's on the back of the tv. i have never had a problem doing this. except when the tv has a "fixed" out, and not a "variable" out, like my mitsu :rolleyes::mad::(
with a fixed out, the tv will not control the volume. a variable out will control the volume.
xego
xego
Right like "just some guy" said, if you only have a connection with a mini jack then maybe radio shack has something to go to RCA but not sure. I had to answer on this post as I was just thinking today about my first "Surround Sound" was also a PC set up. It was in a tiny bedroom so it actually worked alright. Prologic was all there was unless you were lucky enough to have a Laserdisk player...lol
