croseiv
croseiv
Yeah, I have no doubt the entire building will shake. I know If I had had mine back when I was an apartment dweller, the entire unit I was in plus several adjcent ones would have heard and felt it at moderate volumes (high volume would have gotten me evicted probably).
Chopin_Guy
Chopin_Guy
So I am trying to get this finalized in its setup so I can take some photos, but I had another question...am I going to have any issues with the cabinet against my concrete floor....or is there any type os isolator or pad that I should look into getting for this thing....I don't want the floor to crumble underneath it...:D
mazersteven
mazersteven
Auralex SubDude
http://www.auralex.com/sound_isolation_subdude/subdude.asp
http://www.auralex.com/c_sound_isolation/c_sound_isolation.asp
Chopin_Guy
Chopin_Guy
Thank you Mazer....although can you purchase off the website...I couldn't find that?? And are you suggesting this a must have with the sub on concrete or just as a solution if I want to isolate it a bit...?? Thanks man...
mazersteven
mazersteven
I'm not sure if it's a must have. But I would if it's just concrete with no carpeting.
