To explicate a bit more on this, if you look at these graphs as an example:
The lower graph is simply a 2D profile image of the upper 3D graph. If you want to best see the shape of the direct axis response, look at the top contour of the 2D profile graph. The direct axis response is almost always where the speaker will be producing the highest amplitudes, so it will be at or near the top of that ridge. Every successive line going down from that 'ridge' is just responses of the speaker moving further away from the direct axis angle. The outermost angle is at 100 degrees on these particular graphs, and that is obviously way off axis, in fact it is slightly closer to the rear of the speaker than the front.
So, to answer your question more fully, yes there is a traditional direct response here, but it is packaged in by off-axis responses, so you can see the speaker's behavior not just directly in front of it, but all area in front of it. As Mr. Poes explained, a direct axis response alone is not enough to characterize a speaker's performance. It needs context. Furthermore, many speakers weren't designed to be listened to on direct axis. Some speaker designers expect that the user will angle the speakers straight forward in parallel lines, some expect a slight toe-in, and some expect a severe toe-in. These graphs can indicate what angle will make for a more preferable sound to the listener. For example, take a look at this response:
Obviously that would make for a really bright response on the direct axis. but if you follow the lines, you can find an angle that will make these not quite as bright. Compare the 50 degree angle response with the direct axis response:
The 50 degree angle is much more tolerable- still bright, but a bit easier on the ears. These speakers were not intended to be listened to on direct axis.
