Paradigm Monitor 7v5 or Energy C-500 ??
F
fillytown
Hey guys,
im looking at upgrading my mediocre yamaha sound system (5.1 system with a powered subwoofer) by upgrading the front speakers by getting some floorstanding speakers. Although ive just started researching, i've found that i've taken a strong liking to the Paradigm Monitor 7v5's and the Energy C-500's. They're both the same price ($790 cash Canadian, taxes in).
Which one would you guys recommend? is there another speaker in this price range I should look at? I live in a small town, so its kind of hard to find all these brands you guys mention on the site. But do you think I'm getting a good deal?
Anyways, what do you think? which speakers would you get? the Paradigms or the Energy's ?
Thanks!
F
fillytown
Energy C-500 SPECIFICATIONS:
System Type: Bass Reflex, Rear Vented
Recommended Amplifier Power: up to 150 watts
Nominal Impedence: 8 ohms; Minimum Impedance: 4 ohms
35Hz-20kHz +/- 3 dB
Frequency Response:
30 Hz
Useable Bass Response
(-10db Anechoic):
Sensitivity
anechoic 91dB
(2 speakers in a typical room): 94dB
Crossover Point: 1.2kHz and 2.5kHz
Components:
Chambered 1" Aluminum Dome,
Dual 6-1/2" Composite Fiberglas cones
Overall Dimensions:
W - 8"/20cm,
H - 37.5"/95cm,
D - 14.5"/37cm
Cabinet Finishes:
Cherry or Black Ash
Approx. Speaker Weight:
44.1lbs / 20kg
(1 speaker)
Included Accessories:
Spike Kit, Rubber Bumpers
billy p
billy p
Energy speakers are close equals to the digms. IMO I perfer the Energy speakers and the reason is simple, they allow their retailers more headroom from their MSRP.
F
fillytown
so i ended up buying the paradigm's!
they had to order them in, so i should have them next week!
Came up to $775 CDN cash with taxes. good deal i think. :)
billy p
billy p
I have not priced out digm's. That said, $775.00 with GST I would second that as a good score!
Good luck & enjoy, Bp:)
