Well, what exactly is a potential buyer supposed to do? Frustrating. It seems that both reviewers used the CEA standards, testing at 2m. If a shopper can only compare reviews done by the same tester because the testing methods are so variable, then it is really hard to make an educated choice. Most people don't have the time and don't want to pay return shipping in order to buy both and test in their own home. I guess it is what it is. Looking forward to the Audioholics review of the PB12-NSD, for sure.
Gene, where can you find the numbers SVS posted about the PB12-NSD's output? The only graph I see on their site is a frequency response curve and it says specifically that it should not be used to judge max output. How do SVS' numbers compare to the LM-1-EX that you guys tested?
As far as DVDIT's post, it seems that the PB12 might be a good option for your HT, given that it seems to have better ultra-low bass output than the Outlaw. I would guess that it would out perform a cheaper sub like the FV12, but that is pure conjecture on my part. Since you said price is not a factor, maybe you can get 2 of the models being discussed and settle the debate!
