Hi...
i have an older Arcam 137 dvd player that i was going to use only for CD playback but i noticed i have several audio output options (going to a marantz AV7704). I have optical, stereo out (which i assume is analog?) and HDMI so which one to use?
Given that the unit has the old HDMI 1.1, I would use optical. Also, the Arcam has a better DAC than the 7704, so if you use digital, select PCM output or just use the analog outputs for music, select pure direct and hope Marantz won't convert it back to digital and back to analog again, as it may do just that..
. The Marantz has a decent mid range DAC chip on board, so the difference on paper may not translate into something audible.
