Just a small revision.
Hi Josten,
What I mean is, that when you performing the Audyssey Automatic Room EQ Calibration, Audyssey is bypassing any type of processing, uncluding THX, in order to do the microphone measurements accurately.
Of course, after the measurements are done, you can apply any THX modes on top of Audyssey EQ, or any Audyssey EQ on top of THX, whatever.
Except for THX re-EQ with Audyssey "Flat" target curve. Then the THX re-EQ feature is automatically disable. Is that makes sense?
** About the x-overs choosen by your Onkyo receiver(s).
[After performing Audyssey Automatic Room EQ calibration.]
1. First, let Audyssey runs it's Automatic Room EQ calibration.
2. Then check the x-over points; if they are too high (which I highly doubt), you can lower them, but by not much (10hz to 20hz max). Anyway, it is very unlikely that this will ever happen (perhaps with very small satellite speakers).
* If they are too low, you can adjust them higher to your taste.
And if your speakers are set as full range, you can pick any x-over of your choice (80hz being a good one).
--> Is that sounds reasonable to you, Josten?
Regards,
Bob
