my new Onkyo TX-SR608
Well, I've now spent a full week with my new Onkyo TX-SR608. I haven't tried all of the different settings, nor have I really pushed it to its limits, but I'm getting comfortable with it, and I REALLY like almost everything I've discovered so far.
My concern about heat buildup was addressed the moment I opened the box and peeled back the plastic wrapping. As with the European model in the German article previously mentioned in this thread, I could see the fins of a huge heat sink and a good-size fan (120mm diameter, I think) through the slits in the top of the case.
The fan is so quiet that I can't hear it at all unless I open the front of the AV cabinet and put my ear within about 2 feet of the reciever, and even then it's just barely a whisper. It moves enough air that I haven't noticed anything in the AV cabinet getting warm, even during the one time I cranked up the volume to the point where my wife put her fingers in her ears and retreated to the other end of the house.
The power cord is hard-wired instead of modular, as on some higher-end units. Also, there are no AC outlets on the back of the 608. My old Denon AVR-2800 had two switched outlets, and I would have really missed that feature if I hadn't already put a Panamax power conditioner in the center section of my AV cabinet.
Connecting the rest of my gear was a snap. The HDMI ports and speaker terminals are clearly labeled, logically laid out, and easy to reach as you add more wires. The only part of that task that required some reading in the manual was figuring how to attach my bi-amp'ed front main speakers. (This configuration forces you into a 5.1 setup, but I wasn't planning to buy surround back or high/wide aux speakers anyway.)
With regard to cabling, I have run into one slight disappointment: I haven't been able to get the Audio Return Channel to work. I'm not sure if this is a problem with the Samsung TV or the Onkyo AVR. (The cable is brand-new, and according to the box it's "HDMI 1.4 compliant with ethernet", so I'm pretty sure *that's* not the problem.)
There doesn't seem to be a setting in the HDMI section of either device's menu tree to force ARC to be "on". The only choices I've found are "OFF" and "Auto", so my wild guess at the moment is that each unit is waiting for the other to initiate that part of the linkup.
Advice on that issue would be appreciated, and I'll keep researching and trying stuff on my own. I'll report back if I come up with something that works. In the mean time, I've added a digital optical cable to the mix. I already had antenna and Ethernet cables in addition to the power and HDMI cords going up to the TV, so one more cable isn't that big a deal.
The Onkyo remote is supposed to be capable of controlling other gear via the usual trial-and-error device-code entry method we've all come to know and hate over the years. Since I have a Harmony 900 remote, I didn't even attempt this. I did at least put the batteries in, figuring I might need to call up some of the little-used functions that I hadn't bothered to program using the Logitech software.
The Faroujda DCDi video processor hasn't had much to do so far. The input from my Blu-Ray player is already as good as it gets, and what comes in from the AT&T U-Verse set-top box isn't far behind. On that input, the picture comes in at 1080i (60Hz, 24-bit), and it goes out to the TV at 1080p (60Hz, 30-bit).
I should add that I only know this because of the 608's "Info" screen overlay; I can't switch the settings fast enough to tell a difference. As sharp as the Samsung TV's picture was before adding the Onkyo AVR into the mix, I suspect I wouldn't notice any real improvement even if I were able to see them side-by-side.
The video processing was just a nice-to-have, anyway; the real reason I got this particular receiver was for the *sound*, and the Onkyo 608 has exceeded all my expectations. Now I'm no audio engineer, so won't throw out a bunch of spec's and buzzwords without knowing what I'm talking about. I do have a critical ear for music, though; and I loved what I heard from the moment I fired this baby up with factory-default settings. Highs were crisp, midrange vocals were so clear it was like the artist was right there in the room, and the low end was assertive without being 'muddy' or 'booming'.
The one downside to the sound was that I started to hear flaws in some of my MP3 files. The Onkyo "Music Optimizer" setting did help quite a bit with this issue, but at some point I'll probably end up re-ripping my CD collection in a lossless format, since I've got plenty of space on my media server.
After sampling a CD or two and a chapter or so from a couple of DVDs, I moved on to really tuning the receiver and speakers for the room with Audyssey 2EQ. It was easy and painless, and it resulted in a much better sound on all media. The "sweet spot" was noticeably larger, and the individual speakers seemed to almost 'disappear'. With the factory defaults, I could easily point to each speaker with my eyes closed; that was much more difficult after the tuning software had woked its magic.
The resulting setup wasn't completely perfect, however. Remember that I mentioned earlier that I'd decided to go with a bi-amp configuration, which required an explicit setting to that effect in the receiver's configuration menu tree in addition to the extra set of wires. Despite this setting -- and the clear implication that the front mains were NOT little piddly bookshelf speakers -- the 2EQ process still set the low-end cutoff frequency at 40Hz, resulting in a slight but noticeable drop in bass output.
I went back into the menu tree and found the spot where I could change the crossover to "full range", fixing that issue. With that last change, I think the sound I'm getting out of this AVR is now firmly in the 'awesome' category.
Programming the Harmony remote is still an ongoing process, but I'm now pretty close to what I consider a 'final' configuration. The biggest problem I had at the start was figuring out what Logitech decided to call the port for my U-Verse box. The Blu-Ray player was on the "DVD" port, but there was no "CBL", "SAT", or "DVR" listed in the Logitech software; just "VIDEO1" through "VIDEO6". A bit of trial and error showed me that the correct selection was "VIDEO2".
So am I pleased with my purchase? Absolutely. This was the perfect AVR for me. In retrospect, I should maybe have waited another few days, though. Since I placed my order, NewEgg has dropped the price by $5, and they're also throwing in an iPod dock now, if you order by 10 May. From what I've read about it, I don't think I'd want to *buy* the dock for $90+, but getting it for free would've been nice. Oh, well. I've gotten a lot of enjoyment out of the receiver this past week, so that's got to be worth something.
Well, that's it for my mini-review of the Onkyo TX-SR608. Comments are welcome, and drop me a line here if you have insights on that Audio Return Channel thing. Is anybody out there doing that on *any* HT gear?
Regards,
bp
AVR: Onkyo TX-SR608
BDP: Samsung BD-C6900
HDTV: Samsung UN-55C7000
mains: Polk Audio RT800i
center: Polk Audio CS245i
surr.: Polk Audio FX300i
sub.: Polk Audio PSW250
