Onkyo TX-SR608 problem... Low volume
psbfan9
psbfan9
Has anyone found a good solution to this? I just bought the receiver. With my cd player connected thru the rca's, I had the volume up to 99. it was loud, but not 100 watts loud. I feel that somehow the output is being restricted.
Go into the menu and change the 'Dynamic Volume' level. The choices are light, medium, and heavy. Light should be enough to do what you are wanting but play around with the settings to see what works best for you.
L
Laudio
Did changing the 'Dynamic Volume Level' work??? My g/f is having the same problem on her system. We can't tell if the problem is with the Receiver or with the Oppo??? The volume maxes out at 80 and at 35 you can barely hear anything.
