J jeannot Audioholic Mar 27, 2011 112 0 0 Ontario Apr 1, 2011 #21 GranteedEV said: when in doubt get seven krell monoblocks. Click to expand... As much as I would love to welcome Krells in my dreams, I would have to be selective. The KAV 250 gives 207.4 watts in 8 ohms, and 407.9 watts in 4 ohms. That is probably as close to perfection as one can get and certainly the best I have ever seen. However the Showcase 7 tests at 140.4 watts in 8 ohms, and 201.7 in 4 ohms, showing that even Krell employ accountants.
lsiberian Audioholic Overlord Nov 17, 2008 12,393 0 113 On A Bridge in Fort Worth Apr 1, 2011 #22 Why should we raised the price point for people over headroom that really isn't necessary for the general public? How realistic would it be to simply upgrade your amplifier's power supply? I think for a person of the OPs expertise it would be an option work exploring. As a HK owner I still much prefer the Denon approach.
anamorphic96 Audioholic General Aug 21, 2004 1,317 0 63 53 Northern California Apr 1, 2011 #23 lsiberian said: Why should we raised the price point for people over headroom that really isn't necessary for the general public? How realistic would it be to simply upgrade your amplifier's power supply? I think for a person of the OPs expertise it would be an option work exploring. As a HK owner I still much prefer the Denon approach. Click to expand... What is Denon's approach ?
J jeannot Audioholic Mar 27, 2011 112 0 0 Ontario Apr 1, 2011 #24 lsiberian said: Why should we raised the price point for people over headroom that really isn't necessary for the general public? Click to expand... Manufacturers never add quality to their product that is not visible to the general public, so no worries... But every manufacturer has a different level of commitment towards quality, and all I am saying is that ACD test results tend to be an indication of that. How realistic would it be to simply upgrade your amplifier's power supply? I think for a person of the OPs expertise it would be an option work exploring. Click to expand... Out of reach for most people, but not complicated for a technician. And cheap, there's a lot of broken monster amps on eBay with great power supplies (must be of same voltage or slightly less). However as was said before, the extra current capacity, if used fully must be handled by the amplifier's output stage, otherwise poooof. As a HK owner I still much prefer the Denon approach. Click to expand... I think you are saying that for the same ACD power, you would prefer the amp that has the higher stereo power. The advantages are that it also cost less to produce, and is lighter when you need to rearrange your setup. Last edited: Apr 1, 2011
mtrycrafts Seriously, I have no life. Aug 19, 2004 23,551 0 113 Apr 1, 2011 #25 3db said: WIMP!!!! I'm getting 14 mono blocks so I can bi-amp!! Oh yeah BABY!!! and open a welding shop on the side. Click to expand... A welding shop? Much cheaper if you buy a single purpose welder.
P PENG Audioholic Slumlord Oct 23, 2004 19,797 0 113 Ontario Apr 1, 2011 #26 M Code said: Ok lets clear the air... Within an AVR the most costly single component is the power transformer, that is why its specs are frequently decreased... Also the power supply capacitors enter into the cost formula, the lower the capacity and rated voltage the cheaper... Click to expand... No argument from me on this. As I said in my earlier response to jeannot, electronic components in AVRs are cheap relative to their power supplies. Just because of that, I didn't think we can ignore the impact of the electronics such as the output devices, on the AVR's two channel output ratings, and I am not saying anyone did either.
3db Audioholic Slumlord Sep 7, 2002 16,486 0 113 65 Ottawa Canada Apr 2, 2011 #27 mtrycrafts said: A welding shop? Much cheaper if you buy a single purpose welder. Click to expand... C'mon in my friend ..have a seat.. I'll burn those jumpers off the back of your speakers in no time.
