You could just have seperate preamps like you did with your Accurus setup though correct? I could get 3 preamps and some monoblocks or stereo amps and/or multi-channel. Is there an advantage to splitting those up or having them integrated?
I think having separate preamps + separate amps is the purist of all, which I was doing with the Acurus RL11s + 200X3s. At one time I had 4 Acurus RL11 preamps and 4 Acurus 200X3 amps -- until TLS Guy scared the crap out of me with the speaker protection thing.
It's more expensive and takes up more space than having integrated amps, but it's definitely the purist approach.
Actually, I'm hoping that Denon would come out with a minimalist/purist class A stereo preamp (no tones or balance controls) like the Acurus. Then I would definitely buy them plus the POA-A1HDCI amp!
Talk about a pure 2-Channel Analog dream system plus HT.
See, the thing about receivers and pre-pros is that the Front L+R were designed to be super. Most measurements are done for the L+R channels. But what about the THD, F.R., SNR, & Crosstalk for the Center and Surround channels? When was the last time we saw measurements for them?
With 3 separate preamps & amps, every single channel is prestine. Of course, you and I are talking about pure analog craziness here.
Man, I loved having my Acurus gears. If only Acurus had better speaker protection.
Again, it's crazy, but we would not have to upgrade the preamps and amps because they are analog. Only the digital players (blu-ray or whatever-ray player) need to be upgraded, which is inevitable anyway.
Now if we had the KRELLs, why would we want to upgrade? I wouldn't.
Krell is pure 100% evil.
