Newby Considering Klipsch system
Danzilla31
Bump. I’d like to get a center speaker ordered. Anyone have some advice on this?
The r52 should be fine. The only upgrade from that worth it in my opinion is the R600C and that's probably too high of a price bump
K
Kfox1970
A bigger better center is the way to go if able, it is a very important speaker. Especially if getting towers a small lower tier center will feel lacking.
Which Klipsch center would you recommend then? I can’t afford the 64 iii that’s like $1,000 but something maybe up to $400-500?
Danzilla31
Okay you have the R-52C at $319 you have the RP 500C I'm sure it's a step up but a $200 step up?
The RP600C but that's $719. That is a step up but very expensive. I like massive center channels it is the one channel that does the bulk of the work in movie production
But if your on a budget got with the 52c for know and then upgrade down the road
Have you looked on ebay or other sites to try to score a good deal? Sometimes you'll find used or open box items for good prices
Danzilla31
There's a used RP600C being sold on eBay for $349 I tried to copy the link but couldn't
Danzilla31
Let me look I'll be right back
I think you should look on Adorama they've got some great used options that will be a step up from that center your buying that are in your budget range the RP 600C is my bet
K
Kfox1970
I have seen what looked like good deals on eBay, just don’t understand the technical stuff enough to understand which one I should be looking at. I’ll check adorama too. Thanks
Danzilla31
If it's within your price range go for the RP 600 that's all the specs you need to know right now Lol it's the best center for your budget not much above it except for rf iii one but for your room the RP600 should be great
