Hey guys, first post on this forum, greatings
I am in the middle of building a new 5.1 system that will eventually be upgraded to Atmos 5.2.4. I have been doing research for months and finally had some time to do some auditions and pulled the pin. Here is what I went with...
AVR: Denon AVR-X4500H
AVR Cooler: AC Infinity Aircom T8
Front L/R: Paradigm Premier 800F x 2
Center: Paradigm Premier 600C
Surrounds: Paradigm Premier 200B x 2
Subwoofer: Paradigm Defiance X12
Speaker Cable: Omage 12 Gauge OFC
Bananas: Sewell Silverback
LFE Cable: Syncwire 8m
What do you think of my choices?
So far, I only have the AVR, Cooler, Cables, & Sub but, the rest will be here within the week. Down the road I will add a second sub and 4 x Atmos Height to make it 5.2.4. I am running 5 x satellites from an old Logitech Z5500 with the X12 until the rest gets here.
Anyway, here is a fast and dirty drawing of the room these will go in(not very to scale or accurate). It's dimensions are 17.5 x 11.5 x 8'(LxWxH). We have a sectional that is too large to go width wise so the setup I have now has to stay for the most part. On the plus side, we should be buying a new house within a year that will hopefully have a larger and more acoustically sound living room. Anyway, what do you guys think of the setup? As you can see there are 2 entryways into the room and neither have doors. The diagram shows 2 potential sub locations. Which would you suspect is better to start with? Also, what do you think of the tower locations? Alternatively, I could put them both on the same side of the entryway as the TV/Center.
Any advice at all is more then welcome guys. I will be using this thread during the build and setup to ask for advice and help. Thanks in advance
Sent from my SM-N975W using Tapatalk
