Netflix sign-up options
Squishman
Squishman
So the new season of Ozark comes on I think next Friday so I signed back up with Netflix tonight (a week early). I chose the middle option around $13. The top option was around $17. My Onkyo AVR with NF on says I am getting PCM! What the....?! So I switched over to Amazon Prime and shows were coming in on DD. It seems that in order to get a primo audio signal with NF, you have to pay for the premium service. Can anyone confirm this?
I have the standard Netflix service ($14/mo) and get multich audio.....might be your tv's app is limited (my smart tv Netflix app only does 2ch). Does your app give you any audio choices at all?
Trebdp83
It’s not unheard of for an app to not support Dolby audio if you are not using the 4K version. You have a nice TV capable of 4K HDR. Live a little and spend the four extra bucks.;)
Squishman
Squishman
No settings in the app online or on the TV app.
Squishman
Squishman
Is that the issue? According to NF, the upgrade diff is video quality. It says nothing about audio.
Trebdp83
It may not do anything for the audio. But that show is not in atmos and the Dolby Surround upmixer would be required anyway. Because you are getting PCM from your TV, you can select Dolby Surround or DTS Neural:X processing in the Onkyo. Pressing the info button on the Onkyo remote control, is it showing two channel PCM or Multi channel PCM when watching Netflix?
Squishman
Squishman
In DSur mode (in 2.0 pcm), it sounds good. All speaker icons lit. May be as good as I am going to get even if I upgrade to the $18 option? If true, NF is a huge rip off!
Trebdp83
Figured it was PCM 2.0 but hoped it was doing some multichannel conversion. Not every app from every TV or device supports dolby digital 5.1 on Netflix or some other services. If you like the Android experience, look into the Nvidia Shield Pro. It is a killer streaming machine and does it all. Get the 4K plan and don’t cut that nice TV short.
FWIW I use a non-4k device but still get multich audio (Amazon Fire Stick, pre 4k). You'd probably do better with apps in external devices in the long run....
Odd that your tv gets multich audio from Amazon Prime app but not Netflix, but that's where I think Treb may be onto something that you might need the extra $4 service for your tv app. Sure isn't much info on Netflix page about audio....
Trebdp83
Yeah, it’s all still a mess. I remember not getting atmos on Disney+ once because I wasn't playing it in 4K HDR.o_O It’s worth getting the 4K service for HDR. If dolby kicks in as a result, even better.
William Lemmerhirt
William Lemmerhirt
I’m gonna guess it’s th NF app too. We downgraded from the premier version since we didn’t need all the screens so why bother. I also found out that since I don’t use a 4K display, NF won’t use the Atmos track on shows that have it. Vudu does the same thing.
But still. I use NF in one room with my dish network receiver and I get 5.1 streams. In two other systems I use a Sony x700 and another Sony bd player. I get 5.1 streams there too. For these reasons I wish they never even put apps in the damn tv. I’d get a streamer.
Best new EVER tho is Ozark S3 is almost here. Been waaaaaaaiting for evuuur.
Squishman
Squishman
I just turned on NF with my bedroom HT with a TCL TV and Yamaha avr and I am getting a DD signal. HDMI lit in red. Not so on my living room system. With that info, does it seems like the $4 upgrade would not do it. Looks like I suppose I could watch Ozark on the bedroom system. It is a nice 5.2.2 system with Heresy III's. Good to know I need a device if I ever settle on more NF. Tonight, I could even find anything to watch anyway!
Squishman
Squishman
Interesting about the streaming devices! I was not even aware of them until Trebdb83 mentioned it to me a week or so ago.
Squishman
Squishman
I upgraded to the $18 plan. Didn't change the audio unfortunately. Thx for the help. Looks like I need the device..... if I decide to go back to NF on a more permanent basis. At the moment, it's only for Ozark. ha. And "Dead to Me" whenever the new season happens to hit.
Squishman
Squishman
Correction: bedroom system is also PCM on Netflix. Looks like I need the streamer!
