SVS Ultra Excellent Monitor Audio Bronze or Silver Polk LSiM 703
mazersteven Audioholic Warlord Aug 5, 2020 #21 SVS Ultra Excellent Monitor Audio Bronze or Silver Polk LSiM 703
A Aayush Garg Enthusiast Aug 5, 2020 #22 I was comparing sr6014 and sr5014 both have same dac but sr5014 dont have clock jitters What is clock jitters and is it worth considering ?
AcuDefTechGuy Audioholic Jedi Aug 5, 2020 #23 Aayush Garg said: They are too expensive in my country and i need bookshelf speakers not floorstanding speakers Polk audio, elac, dynaudio, klipsch, wharfedale, b&w, kef, svs, fyne audio, focal, q acoustics, monitor audio, Click to expand... I would go with Dynaudio, KEF, Focal, Monitor Audio.
A Aayush Garg Enthusiast Aug 5, 2020 #24 mazersteven said: SVS Ultra Excellent Click to expand... I also want it but they are not available in my country
AcuDefTechGuy Audioholic Jedi Aug 5, 2020 #25 Aayush Garg said: I was comparing sr6014 and sr5014 both have same dac but sr5014 dont have clock jitters What is clock jitters and is it worth considering ? Click to expand... I would not worry at all about any difference in DAC or Jitters or anything else.
mazersteven Audioholic Warlord Aug 5, 2020 #26 Aayush Garg said: I also want it but they are not available in my country Click to expand... You listed SVS
A Aayush Garg Enthusiast Aug 5, 2020 #27 AcuDefTechGuy said: I would go with Dynaudio, KEF, Focal, Monitor Audio. Click to expand... Can you recommmend any particular model bec not every model is available in my country
A Aayush Garg Enthusiast Aug 5, 2020 #28 mazersteven said: You listed SVS Click to expand... Yeah but only prime series nd ultra towers is available
AcuDefTechGuy Audioholic Jedi Aug 5, 2020 #29 Aayush Garg said: Can you recommmend any particular model bec not every model is available in my country Click to expand... Whatever is in your budget. But I like those brands. They make high-end speakers and a lot of the same technology is also used in their lower-end speakers.
mazersteven Audioholic Warlord Aug 5, 2020 #30 Aayush Garg said: Yeah but only prime series nd ultra towers is available Click to expand... Prime is nice too
mazersteven Audioholic Warlord Aug 5, 2020 #32 Aayush Garg said: How about klipsch rp600m i've read very positive reviews Click to expand... I'm not a Klipsch fan but that doesn't mean they are no good
lovinthehd Audioholic Jedi Aug 5, 2020 #33 AcuDefTechGuy said: That will work and sound just as good as an integrated amp or stereo receiver with similar power-rating Click to expand... Altho all the setup thru those tiny porthole windows without a tv might be a pain....
AcuDefTechGuy Audioholic Jedi Aug 5, 2020 #34 lovinthehd said: Altho all the setup thru those tiny porthole windows without a tv might be a pain.... Click to expand... Just use the LCD for adjusting the speaker trims/channel levels, source select, and volume. He doesn't have to do auto room EQ or anything else, which he wouldn't do anyway with an integrated amp.
