Okay, here's a few different angles of the room including one from sitting on the couch looking at the TV. I'm open to changing the room around if necessary though not sure how to do it and have the amount of open space I have now.
Also, the dimensions of the rooms are as follows:
Ceiling Height, 8 feet
Width, 14'10"
Total Length from doorway, 290 inches (little over 24 feet)
I guesstimated that the flat part of the ceiling is roughly six feet across as well.
So with all that being said, if I was hellbent on Atmos, is that even a remote possibility? Heck, is even a standard 5.1 possible? And if I did want to rearrange the room, in which manner would be optimal, and how would that enable me to do?
Also, for my education, why are soundbars, even the new Samsung N950 setup, for example, not the way to go for most?
I'm fine with piecing the system together that I choose, just need something right now that's better than the TV speakers on the OLED.
I guess I should start with a receiver and bookshelf type speakers and a sub or a 2.1 setup initially and go from there?
You have no idea how much I appreciate this advice. I have been spinning my tires for literally months here. I did go to a home surround sound type store, which recommended if I wanted Atmos to put the two speakers in the ceiling above me, would be my only option for it because of the funky ceilings I have. Other than that, it's all been reading, reviewing, and changing my mind constantly as I have no clue what the hell I'm doing!! Haha.
