need some help here
Z
zumbo
I feel you will be pleased with Yamaha. Be sure to take time for proper set-up. Don't just plug-and-play.;) Please come back to this thread and update.
Z
zumbo
jsanfilippo5 said:
id really like to audition som eof these speakers out there. Axiom, fluance... any experience with either?
Fluance is junk.
What's the budget?
jsanfilippo5
around 1500 for all 5 including sub.. - I can get floorstanding though - i need bookshelves due to space.
jsanfilippo5
ive read good things about there subs, havent heard much about there speakers though...
jsanfilippo5
awesome - thanks... i never ordered from accessories for less.. any goiod?
Z
zumbo
I have ordered some cables from them in the past. They have been around for a while. They are lagit.
Mordaunt Short gets good reviews here. There are a few members that use them.
jsanfilippo5
thanks alot - you are a huge help... im going to pick up that yamaha tomorrow when i return the dead denon. I think the bostons are going to go back as well..
Z
zumbo
Where did you get the Boston's from?
jsanfilippo5
i bought the bostons at circuit city.
i checked out what they had from polk and wasnt inpressed. they had the monitor 40... i was never a big fan of polk.. although i never had a achance to sample the higher end stuff...
jsanfilippo5
i bought the yamaha htr-5960 and I couldnt be happier. The bostons sound very good through this amp, still looking to replace the fronts though. I dont know if these would be overkill for the rears.....
