ahblaza
ahblaza
E
evpj13
If you don't mind me asking, what is wrong with Polk sub's?
The Polk Audio PSW10 has a 4 1/2 star rating with 200+ reviews...and it's less than $100? For that price, and that many positive reviews...I'm inclined to ask why you said to stay away from them.
Thanks!
Polk's subs just aren't that good. No other reason. If you are using audioreview or something similar for ratings, that is also a mistake. These are not professional reviewers and most have nothing to compare the product to. Of course it has it's place on the food chain as a basic sub. However, you asked for recommendations and I can't recommend their subs. It also depends on what you are after. For music, that thing isn't bad, but if you want something that will fill a decent sized room and go deep, the PSW10 isn't it.
How big is your room? In a bedroom that particular one might be OK, but in a typical living room, no so much.
