Need Help finding a low profile onwall for surround duty
baltik
I am rather upset right now, after a ton of research and some bargaining I found a great set of inwalls by monitor audio to use as my surrounds. Unforunately as soon as I opened the walls in my 1880 built house I was dismayed to find a non standard beam directly in my path. Since this is lathe and plaster it was undetectable by a stud finder.
So need to find a good speaker for surround duty preferably low profile (ideally 4"-5" thick) since this is in a corner I cannot use a dipole. I am looking at some mythos gems but they are a little chunky for the space - anyone have suggestions?
Setup is as follows - Ascend sierra fronts with jl audio f112 sub
baltik
Looks like the surrounds would work well but they appear to be angled which would be less than ideal in my setup, any other suggestion? Bonus points if the speakers/grilles are paintable
Bugbitten
Axiom Audio offers QS4s or QS8s in antique white that is paintable.
Davemcc
Davemcc
They are not angled. They sit flat to the wall and aim straight out, unless you mean that the sides are slightly tapered front to back. You can order silver grills on the Cinema Series instead of black, if that helps.
