Need Assistance Selecting Speaker Wire?
JEidt
Hi all,
I recently purchased a set of Polk RTi8 fronts, a CSi5 Center, & a set of Rti-4 surrounds based on my budget & audioholics.com member recommendations. These speakers will be attached to a Pioneer 52tx Elite Receiver.
Please recommend a particular vendor for about 100 feet of speaker wire.
Also - what is biamping? Both the Polks & Elite are biampable.
What does this mean?
How do I connect the wire to the Reciever & speakers?
The receiver has Banana Clips.
Also - 25 inches of snow in Danbury,CT
Thanks again,
John
L
louhamilton
I recently purchased 100' of 14ga Philips wire from Lowe's for about $25. I also bought some banana plugs from Rat Shack. Later, I will probably get some heat shrink to "pretty" up the cables that are exposed.
-Lou
JEidt said:
Hi all,
Thanks again,
John
I would support Lou on this recommendation. Buy 14ga or 12ga, by price, not brand name, unless the looks of that cable is important:D
Jay M
I just yesterday installed new speaker wire from Rat Shack. I wanted something flat to go under the carpet. Their 14gauge was $19 for 50 feet. I also used their Banana plugs. I like how tight they fit and the fact that I can solder them
http://www.radioshack.com/product/index.jsp?productId=2103479&cp=&kw=banana&parentPage=search
The only problem I have with the wire running under the carpet is that the ceramic blocks that suspend the wire make the floor lumpy ;)
But seriously everything worked well accept that the polarity isn't marked on the wire. I had to use a multi-meter and a Sharpie to mark them.
~Jay
jcPanny
jcPanny
Belden speaker wire
Check out Belden 5100UP (14AWG x 2) or 5000UP (12AWG x 2) from weslake for $0.18 / foot. It is high quality copper wire with a PVC jacket that is rated for in-wall installation.
http://www.westlake-electronic.com/
~Jay
Can you expand on these ceramic block? Why are they there? I am not picturing their roll in this.
mike c
mike c
you mean you don't suspend your boombox on a ceramic block? you've been in the dark all these ages. you will get better sound when your boombox is on top of a block (even when on top of a desk) :p :rolleyes:
ESPECIALLY when you load it up on your shoulder. you will get a surround effect when you do this. :D
Jay M was making a joke i think.
Sheep
Sheep
Funny story,
Guy at my work was talking about a totem demo/conference he went to, and they brought out the totem "beak". Its a medal bullet, that they placed on top of the speaker, and he said "you could instantly hear the difference"
I almost slapped him.
SheepStar
DaveOCP
I've had very good results with surplus mil-spec silver coated copper teflon wire. A 50ft, 12AWG roll is maybe $20. It's funny, some companies like XLO and Tara Labs say that silver coating is the worst thing you can do to speaker wire. Other companies like Nordost and Wireworld use it in their mega-buck flagships. Who's wrong?
Sheep
Sheep
Well, silver in not very durable over time. Gold would be a better coating.
SheepStar
tomd51
tomd51
12 or 14 AWG Spool From Hardware Store..
I was able to pick up a 250' spool of 12 AWG wire from Lowes for just under $40.00. The polarity is lightly labled (one wire no print, the other light print), so it is distinguishable. Great for long runs, solid jacketing as well.
I've been using this cable for over 4 years, without any fancy schmancy ceramic wire/cable elevators and the signal is as clean as a whistle... -TD
JEidt
In Wall Speaker Wire vs. Outside Wall
I plan to run the speaker wire on top of the carpet against the perimeter of the room. The speaker wire will not be seen
My question is: Is the 12 AWG wire for in wall or outside wall use?
How do I biamp the speaker wire? Both my receiver & speakers can be biamped. I have read that biamping is the way to go.
Any comments or suggestions would be welcomed.
markw
That depends on the speaker wire you buy.
You simply run two pairs od speaker wire between the two amps and the speaker.
In some cases, maybe, but why do you think you need it? Seriously, do you know what it is and when it can help?
3db
3db
Slap him one for me will ya.
Sheep said:
Funny story,
SheepStar
*mutters something about snakeoil bull sh?t!!!*
