Hi Gents,
You won't believe this but my friend just came back to me, and asked me to help him replace the MIT Cables, as he desperately wants to avoid another AR amplifier failure. He never hooked the system up after he got the repaired AR Amp back, as he pondered what to do next. He said that 90+% of the time the failures occur when he is playing vinyl, so to start (as a bit of a compromise I thought) I suggested we replace those MIT cables in that pathway first (he initially wanted me to just do them all). All of his interconnects are MIT and have boxes on them - some have 2 boxes on each end!
When I arrived at his house he had already disconnected the Speaker Cables and replaced them with a very decent pair he already had in hand. So we are looking for some Interconnects. The first is a pair of
30 foot balanced interconnect cables from the pre- amp to each power amplifier. Next is a
3 foot (yes 36 inch) pair with RCA jacks for the phono cartridge to phono RIAA pre-amp. The MIT RCA Cables installed had a very interesting clamping collar on the RCA connectors. (I've never seen them before, but they were impressive.) He also wants an 80 inch pair of Balanced Cables from Mark Levinson CD Digital Processor to the Pre-Amp.
Swerd, these are the first generation of Wilson Maxx speakers.
Sorry if I didn't confirm this earlier. Today I again advised my friend that if the cables are not the problem, it's probably the impedance mismatch between the AR Amps and the Speakers. (I sent him a link to the Stereophile's Review and a copy of the impedance graph ages ago.) He said he doesn't think that's the case, as he had no issues with the AR Amps for at least the first 5+ years of ownership. But I am not guaranteeing the cable change out is the total remedy! But at least it will eliminate the MIT "Boxes" from the equation.
Personally, I am just fine with Monoprice Cables for my gear, but I was hoping for a bit better esthetic as the long cables are visible running to the Monoblock AR Amps. I checked out Blue Jean Cables, but their Balanced Cables use only
Belden 1800F Balanced Audio Cable which is pretty plain with no "woven cover" like the MIT balanced cables.
The Belden 1800F is single shielded and I've just read some technical papers where the twisted pair and the outer shield are more than sufficient for magnetic, or radio frequency (RF) interference, as long as both ends of the shield connect to the chassis of each device involved via the XLR Connector. (Modern balanced cables should always be manufactured this way. I know some folks do "lift" the shield of one end when bothered by humming. Hopefully we'll see none of that here. ) As I mentioned earlier, my friend's security technician (he's got about 30 wireless cameras all over his property) suggested the RF from those devices, or RF noise from the VHS radios on the Boats / Ships going by => as my friends house is right on the water near Deep Cove, BC => may be causing the problem. So now I can debunk that theory.
I just noticed the Blue Jean / Belden 1800F Balanced Audio Cable has
 a 24 AWG twisted pair, and the Monoprice Premier Series XLR Male to XLR Female has a 16AWG twisted pair. Comments please.
I remember a late night review
@gene did where he mentioned some "good looking cables" but I think they were speaker cables and not interconnects. Perhaps he can advise.  (Not likely...I guess.)
Do you guys know of any "pretty" balanced cables (OMG!) that will do the job? Or should I look to sourcing some woven covering and shrink tubing and do it myself over one of the cables mentioned above?  Sorry to bother you again but I really like to get this sorted once and for all.
