My XBOX360 Broken Again!
MinusTheBear
MinusTheBear
My 360 does actually power up and even when its powered up the PS LED is orange. I believe there are now 4 Red LEDs on my 360 when its on. Originally it was 3 but now I see 4 flashing red.
4 Flashing red lights indicates either
1) The audio-visual (AV) cable is not correctly connected to the Xbox 360 console.
2) The cable is not being detected by the console.
Considering the fact your console was freezing all the time and the console did show an internal hardware failure (3RROD) and was unplayable before this other stuff started, I still think the console itself is the culprit causing these problems.
gene
gene
Audioholics Master Chief
Administrator
Ah I plugged it back in with no A/V cable just to see if it would power up. That explains why I not see 4 instead of 3 flashing red lights.
So if you unplug your 360 from the PS does the PS turn orange?
thanks for your help. You seem well versed in Xbox failures :D
MinusTheBear
MinusTheBear
If the power supply is connected to the eletrical outlet but not connected to the 360 the power supply light should be orange. Orange on the power supply represents it is in standby so the power supply should read orange if the power supply is connected to the 360 and the 360 is off or if the power supply is not connected to the 360 and plugged into a outlet.
