I would suggest you combine the two suggestions you have in the beginning
of your thread. It will be a lil' bit more complex but will achieve better picture of a person's perception regarding audio compressions in relation to loudness. It would be advisable to use 3 different audio compressions with 3 different level of loudness. I would think it is best to subject the volunteers to listen to the lowest audio compressed then the highest and lastly the mid-audio compressed track. Give them each 3 seconds to rest their ears (i don't know why i pick 3). With simple statistics analysis this can be done pretty easily.
That would be an interesting topic, but I believe starting with dynamic music vs dynamically compressed would be ideal and perhaps expending the research later would be more ideal. Also, there has been more than enough research regarding perception of loudness as well as dynamics vs loudness in my honest opinion.
Likely the plan will be have two 25 second intervals that was originally a dynamic source one being the lossless copy and the other being dynamically compressed. Rotating which is A and B between subjects, so the lossless copy isn't always heard first further eliminating bias. I have yet to determine timing, but will likely have the participant listen to the first clip wait ten seconds then listen to the second (keeping it in one file so the timing is not done by hand). I will allow each participant to listen to the full file as many times as they would like. Once they feel they have had enough time with the piece I will give them a questionnaire which will ask various questions to help determine which is liked more and factors involved with that choice.
If anyone sees any problems with this, has questions suggestions or any comments at all let me know
In a research like this, there should be several assumptions need to be made, such as: little or no interference from outside noise, the headphone used has linear frequency response and the audio track covers lowest and highest audible frequency and don't forget, the samples (persons who are picked to be the victims of your research) are not tone deaf...
1) Outside noise will be controlled for by using over the ear headphones and use of a quiet room
2) The headphones I am looking to purchase have an almost perfectly flat response and a calibration file will be used to ensure complete linearity
3) The tracks don't actually don't need the full range of human hearing. The project is comparing if the subjects prefer a dynamic source vs a dynamically compressed source. As long as there is a quality recording that is very dynamic especially when compared to the compressed source (think jazz or an orchestra).
PS: May be take a sample of equal number of sexes (male/female). Then you can see how different the two sexes are in this research.
I do plan on having both sexes in my study, but there is no need for the samples to be equal. If the groups are each large enough, regardless of size actual size, statistical analysis can still be done successfully.
Lastly, I am trying to come up with some good dynamic music sources to use for the study. I am thinking something that many people haven't heard will be ideal so the subjects will not have a preconceived idea of how the specific song should sound. Does anyone have suggestions? Right now I am thinking that I will use a track from Chesky records or Jazz in the Pawn Shop.
