wilkenboy
Will do - what is its pros / cons vs the Panny? And what have you seen about the Panny that makes it worth the roughtly $200 more than the Sanyo?jcPanny said:Projector:
Also look at the BenQ PE7700 DLP. Right now the price is about $2500, but the price will likely come down closer to the holidays. I would pick the Panasonic over the sanyo.
My cousin has the Panny and its a great unit.
I have a multi-staged approach here. The first step is a DIY painted screen using some of the cool formulations I found on AVS. Should run me around $40 all in - Cheap!jcPanny said:Screen:
DIY, Goo Systems Paint. CRT White or digital grey.
OR, Dalite Model B manual pull down screen.
Also make sure that you run the projector calcs on the model you buy before building the screen. The model you select and its zoom range will effect the available screen size.
My cousin did the Goo Systems to the tune of a few hundred dollars. Problem is it did not go on really smooth (roller technique?) but you can see differences in reflectivity across the surface if a single light color is projected on it. Kind of annoying. Any idea what might have gone wrong here?
If the V1500 has 3 component imputs I'd be all over it, but it does not. I'll need three (XBOX, DVD player, OTA HD receiver). Right now I'm leaning heavily toward the Pioneer 1015tx, but would make the jump to a Yamaha 2500 or Denon 2805 if I can find a great deal at purchase time.jcPanny said:Receiver:
Yamaha RX-V1500 or HTR-5860
How would these compare to the Ascend CBM-170s? I really like the Paradigm Studio 20s and 40s and have heard the Ascends are a very close match for roughly 1/3rd the price.jcPanny said:Speakers:
Axiom M22ti fronts, VP100 Center, M2t rears. Slightly higher than your budget but should perform much better for HT sound.
I'd love to do a side-by side on the Axioms vs the Ascends but its hard enough finding someone with either one let alone both. Perhaps I'll order a pair from both and send the loser back...
Yep, looking at the PB-10 ISD, but considering possibly a PCi 20-35.jcPanny said:Subwoofer:
Rocket ULW-10 (built in EQ! $400!) SVS PB-10 ISD, or HSU VTF-2
Keep in mind that PEQ on receivers will not handle the subwoofer frequency range.
Already dropped some in the walls - home depot 12AWG at $80 for 500ft. 16 cents a foot on a special. Usually around 22-24 cents.jcPanny said:
Funny, as I was just salivating over some reviews of this one today. I already have a Denon 1710 but it will likely be moved to the family room when the time comes. Does this unit do DVD-A and SACD?jcPanny said:DVD:
Save up for the Oppo Digital to maximize the capabilities of your 720P projector. ($200) Also wire room for DVI / HDMI cable.
Currently I've wired for component from the receiver to the projector, but have the attic access so I can run HDMI/DVI later if necessary. What's the max length I can run?
Thanks for all the input!!
~Josh
