Hello,
I am new to home theaters.
I am looking to build a 7.2 home theater. Mainly for tv/movies. I would listen to music on occasion but it would be very rare. I already have a receiver(Denon AVR-X3500H).
My plan was to buy the front two floor speakers and center speaker first. Then the subs later, then the surrounds as money permits.
I am looking at the Klipsch RP-8000 for the front floor speakers and RP-504C for the center.
My question is which rear speakers will go best with this set up? The RP-600M for rear and side speakers? Should I get another set for RP8000's for the rear and RP-600M for side speakers? Or should I go with something like the RP-502S?
I have no idea as I am use to the built in tv speakers.
I am leaning towards dual VTF-3 MK5 for the subs.
Any suggestions for the rear and side speakers and subs will be greatly appreciated. Also if someone has suggestions as to a different brand instead of Klipsch for around the same price I am open. I just really like how the Klipsch looks and I have heard good things about them.
Right now I don't have a dedicated movie room but I hope to in the future. I just want to get the best set up that I can now.
Thanks,
Brian
Some info to help us room size? Budget preferably?
Since your listening habits are movies and some TV you cannot go wrong with the Klipsch new rp line
I owned the rp8000f's a fantastic speaker O enjoyed them thoroughly
I would go with the RP 600m all day and Sunday to pair with those 8000f
For both surrounds and rears that will give you an outstanding system for the buck for both tv and movies
They really are a great set of speakers everything sounded great on them music as well
Your choice of subs is a great call as well but knowing your room size and layout some will help with suggestions for speak ers and subs as well
The klipsch are fairly efficient not as much as klipsch advertises the RP 8000f were reviewed here but they are efficient. So in a system like that you probably won't need an amp to save you some money depending on room size listening distance etc
With a matching set up It will be a nice timber match for the system its not absolutely necessary but many prefer to have all the same speak ers in a line especially in the front 3
