Biggie,
thanks for the explanation. All clear now regarding to the 980H.
One last question on the AVR side, though:
if you got one that processes LPCM, you'll be fine for the DSD or you do need specifically on AVR that accepts the raw DSD streams?
AFAIK, the player is the only one that needs to have the DSD chipset, right?
Could you please elaborate on that either?
Regards, Chuck
The receiver needs to have a chipset with DSD-capable DAC's.
Then it's also worth noting how the receiver handles it. Does it decode it to PCM or is it capable of straight DSD>Analog conversion.
The Pioneer Elite's for example, 9x series, convert to PCM.
The Denon, Yamaha and Onkyo receivers (specific models) can convert from DSD>analog without hitting the PCM realm, using some form of "DSD Direct" mode.
You might also consider which DAC's are being used as SACD has a dynamic range of 120 dB. The PCM1796 and PCM1792 chips have dynamic range of 123dB and 132dB respectively and are both capable of DSD>analog should the manufacturer implement it.
A number of the current receivers have PCM1791A DAC's, which have a dynamic range of 113dB.
Here’s a short list, not including the Pioneer Elite receivers as they don’t support DSD>Analog, which if you’re a purist you may be looking for:
Code:
Burr-Brown PCM1791A 113dB SNR $ 3.00/ea Yamaha RX-V3800, Yamaha RX-V1800, Denon 3808, 4308 and DVD-2930CI
Burr-Brown PCM1796 123dB SNR $ 6.50/ea Onkyo 805/875/905, Denon 5308 and DVD-3930CI
Burr-Brown PCM1792A 127dB SNR $13.00/ea ?
Burr-Brown PCM1792 132dB SNR $13.65/ea Yamaha RX-Z9 and RX-Z11(DSD1792), Denon 5805ci and DVD-5910
I would imagine given the few manufacturers being discussed here that none of them have completely garbage components in the receiver that would render differences in the DAC’s useless, but that’s just my opinion; some may disagree with more knowledge.
