Yes I understood what you meant(sort of...). So there's two different DACs.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Why isn't the Sabre used for everything in the 801, like some of these external DACs?
Also is that a typo above, did you mean "it is NOT a bad one..."
That should be fine anyways. I'm sure I won't be able to discern the difference between the two of them.
The optical will be for TV or movies etc....that's fine. I don't need high fidelity in those areas.
And I like stereo.
One of the reasons I want this 801 is for the USB input so I can run alternate audio from my DAW.
I want to monitor the sound through a different DAC, amp and speakers.
I run my sound through Steinberg(Yamaha) audio interfaces now.
I want to run the final mix through the 801 and different speakers for a final critique.
I was using my car radio's USB input for this purpose but it only accepts MP3 level USB input.
I mix my audio down to 24/48. So that wasn't working that good. I had to convert them down and try dithering and all that garbage.
Any feedback you have on this would be welcomed. Thanks a whole bunch.
I looked at that pcm 501 spec sheet a little. Most of that is over my head.
In response to your other thread reply, I don't need that DSD or SACD stuff.
A regular CD through a boombox or car stereo is rock and roll to me. It's good enough.
I'm listening to alot of music on You Tube. It doesn't get more lo-fi than that.
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks again.
