Info:
I just wrapped up my review of the following Monoprice Monolith 10/12/15-inch subwoofers:
Monolith by Monoprice 10in THX Select Certified 500-Watt Powered Subwoofer - $499
Monolith by Monoprice 12in THX Ultra Certified 500-Watt Powered Subwoofer - $799
Monolith by Monoprice 15in THX Ultra Certified 1000-Watt Powered Subwoofer - $1339
You can watch the video or just look at the data/link posted in the below sections. The video covers a little bit more than is mentioned here but the bottom line is the performance of these subwoofers is really quite good and it is very evident to see just how much more output below 50Hz these offer than "budget" subwoofers.
The Monoliths provide quite a bit of output, have very nice linear response with extension down to 20Hz in the ported configurations. They have a variable phase adjustment which is a *big* deal IMHO (I know others have it as well). There is no chuffing (demo'd in the video) from the port and the mechanical aspects are quiet (no resonances, no motor noise, no tinsel lead slap).
The drive units themselves are quite nice but I do wonder if they would benefit from pole piece (cooling).
Video Review:
Photos:
CEA-2010-A/B Max SPL Testing:
CEA-2010-A & CEA-2010-B test data can be found in the below spreadsheet.
https://docs.google.com/spreadsheets/d/18bz7z-xIlRJsC-bw6k4mHkuwv_uiGAMyEhgrTkjwdXc/edit?usp=sharing
-A test results:
-B test results:
FREQUENCY RESPONSE:
Here are the graphics for the frequency response (not CEA-2010 results; just the FR, taken at 0.5vRMS).
They include ported vs sealed and "extended" vs "THX" EQ in each graphic.
10-inch Monolith Frequency Response:
10-inch Monolith vs the Elac SUB1010 ($130, budget 10-inch subwoofer). You can see very clearly the Elac (which was the better of my recent 10-inch Budget Subwoofer Shootout) is easily bested in linearity by the Monolith.
12-inch Monolith Frequency Response:
12-inch Monolith vs the Monoprice Budget ($99) 12-inch subwoofer.
Monolith 15-inch:
Comparison of all the Monolith sizes, sealed:
Comparison of all the Monolith sizes, ported:
Bottom Line:
The Monolith subwoofers are a very nice value. They don't have a lot of flash to them but what they lack in aesthetics (for some), they make up for in performance and features. The variable phase and XLR input are two features that delineate these subwoofers from "budget" subwoofers. The CEA-2010 testing yielded really solid results, though, to be fair, I don't have many to compare against at this moment in time. But by looking at others' results, I'd say these more than hold their own and present a very high value. There is no internal resonance, port noise is only an issue if you're playing test tones at the lowest of frequencies. Very solid subwoofers with great performance. I recommend them if you're looking at them as an option.
