Monolith M-10 vs M-12 is it worth it?
sgtkahuna
M-10 is $475 and M-12 is $700
The price difference is $225
Purpose: Movies only.
ryanosaur
ryanosaur
Yes. Step up to the 12, and start saving for a second one.
BoredSysAdmin
BoredSysAdmin
Depends on your room. In tiny rooms, m-10 should be enough. in very large rooms m-12 would NOT be enough.
ryanosaur
ryanosaur
But the 12 will go a little deeper and has better distortion performance.
shadyJ
Speaker of the House
Staff member
I would say it is worth it. The M-12 has a major mid-bass advantage over the M-10.
sgtkahuna
Yeah I’d say get the 12 unless op doesn’t listen loud . Regardless 12 is winner.
How loud do you listen & room dimensions,???
I use about 90% of the Sony STRDH590 volume, room dimensions are about 9.8 by 13 feet
Kingnoob
Kingnoob
What sub are you using now? That’s a Small room either sub will be fine but the 12 goes a little lower . I use two weak 10” in one set up and a 15” diy sub in another . So either of the monos get pretty loud and on par with my 15 for sound quality. Really just depends what you want more spl or less . I don’t listen that loud actually so I’d be fine with either .
sgtkahuna
I currently got no sub, just two Encore T6s
