Monitor Audio Airstream S300 Speaker System Overview
HTKamikazee
Audioholics Sheriff
Technology never stops to amaze. Wireless connections have opened an endless spectrum of possibilities. I still remember when I got my first Bluetooth cellphone and how I felt when I transferred my first song from my laptop to my cellphone. It was something out of this world. Now, we have this kind of technology almost anywhere with the existence of devices like smartphones, wireless speakers, wireless headphones, ipads, tablets, wireless battery chargers and the list goes on and on. Simply put, cables are becoming a thing of the past. Years ago we had to put a cassette (tape) or a vinyl disc to hear music. Then came the CD and now we have new technologies like Airstream. Now you simply connect your internet enabled devices and you are ready to enjoy an infinite amount of material in a matter of seconds. One device that I've been looking for some time isthe Airstream S300 from Monitor Audio.
The Airstream S300 is a powerful AirPlay® enabled 140W stereo speaker system, which provides unlimited wire-free access to music streamed from the Internet or stored on computer, smart phone or tablet. This unit is very easy to use, it has a very innovative room EQ software. The EQ system's in-room response is enhanced still further by Monitor Audio's innovative APC (Automatic Position Correction), which compensates for any room effects. An integrated microphone measures the total frequency response, and the EQ system makes the necessary adjustments according to the effects caused by the room/environment. A micro-processor then compares the response with an 'anechoic' ideal, and adjusts the S300 accordingly to recreate the ideal sound balance in any space. The only negative aspect of this device is that it was intended to be used with apple devices. Other than that, I haven't found any drawbacks. As I said, technology never cease to amaze. What will come next?
FEATURES:
  • Multi-Zone wire-less stereo speaker system.
  • Apple Airplay® – stream music from iOS device, PC or MAC.
  • Airplay direct – stream music directly to S300 without Wi-Fi router (point to point).
  • USB input for charging and set up.Fuss-free installation.
  • Discrete high performance stereo sound design.
  • Monitor Audio C-CAM® bass drivers and gold dome tweeters.
  • 140 Watts delivered via four power amplifiers.
  • Innovative Automatic Position correction (APC) system.
  • IR Remote control unit.
  • 3.5mm Auxiliary input.
SPECIFICATIONS:
  • Frequency Response: 55Hz - 30kHz
  • Maximum SPL: 104dB
  • Power output (RMS): Bass: 2 x 50 watts / Tweeter: 2 x 20 Watts
  • Drive complement: 2 x 4" (102mm) bass drivers with C-CAM® metal cone technology / 2 x 1" (25mm) Gold C-CAM dome tweeter.
  • System configuration: 2 Way Ported
  • Auxiliary input impedeance/sensitivity: 10k ohms/300mV
  • Signal to noise ratio: 94dB
  • AC input voltage: 90-264V (auto range)
  • Amplifier category: Class D
  • Power consumption: 0.33 watts (standby); 140 watts (Maximum)
  • Made for: iPhone 4S, iPhone 4, iPhone 3GS, iPhone 3G, iPhone, iPod touch 4G, iPod touch 3G, iPod touch 2G, iPod touch 1G, iPod Nano 6G, iPod Nano 5G, iPod Nano 4G, iPod Nano 3G, iPod Nano 2G, iPod Classic.
  • Works with: iPod Touch 5G, iphone 5, iPad 4, iPad mini, iPad 3, iPad 2, iPad
  • Airplay requires: iPhone 5, iPhone 4S, iPhone 4, iPhone 3G, iPad 4, iPad mini, iPad3, iPad2, iPad, iPod touch with iOS 4.3.3 or greater. PC or MAC running iTunes 10.2.2 or greater.
  • Supported File formats: Airplay; AAC, ALAC, MP3 / Airstream; AAC, ALAC, MP3
  • Wire-less network protocol: 802.11 b/g
  • Color/Finish: Charcoal Grey with black grille cloth / White with light grey grille cloth
  • Approvals: ETL/ CE/ Fcc/CB/ Erp/ Wi-Fi/ Wi-Fi WMM/ Apple MFi Certified.
  • Dimensions: (H x W x D) 15cm x 46.7cm x 15.4cm (57/8”x 183/4” x 61/16”)
  • Weight: 10 lbs.
Price: $499.00
Click on the following thumbnails to zoom in.
What do you think about this device. Are you interested?
