I have mismatched subs. Is it better to use both with the defeat switch set to OUT for avr management or set the Kreisel to OUT so it can handle the mid, upper bass and set the HSU to IN to handle only the low bass? Below are the specs for each sub. Thank you! HSU VTF3 MK4 <TBODY> Amplifier Power (RMS)<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->1400 W Short Term, 350 W Continuous<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Hybrid Tuning<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->16 Hz Ported, 22 Hz Ported or Sealed<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Upper Extension<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->+/- 2 dB to above 200 Hz<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Woofer<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->Side Firing 12 Inch<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Q Control Range<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->0.3 - 0.7<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Crossover<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->30 - 90 Hz, Bypassable<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Crossover Slope<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->24 dB/Oct<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Phase<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->0°/180°<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Inputs<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->Line Level (2), Speaker Level (2)<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="feature" -->Power Outlet Requirement<!-- InstanceEndEditable --> <!-- InstanceBeginEditable name="specification" -->430 W, 120/240V<!-- InstanceEndEditable --> </TBODY> Ken Kreisel 12012 The Power Output is 750+ Continuous RMS watts <TBODY> Driver Configuration DUAL PUSH-PULL 12” HIGH VELOCITY DEEP BASS DRIVERS Typical in Room Frequency Response 10 Hz - 200 Hz Variable Phase Adjustment 0 to 180 degrees Variable Low Pass Filter Range: 40Hz - 160Hz at 12db per Octave Variable Bass Level with Switched Fixed Calibrated REFERENCE LEVEL Setting Variable Low Pass Filter Bypass Switch Auto On/Off switch Only operates when using the RCA inputs Unbalanced RCA LFE/Line Inputs 2 Impedance for Unbalanced RCA Inputs 8k Ohms </TBODY>
