GranteedEV,
Let me rephrase and see if we have a more common understanding. An improper phase integration can lead to the sub volume level set unreasonably high and lead to the triggering of limiter more often than not. Then Paul began to fault the volume dial. Come on, our volume dial is like 15 degrees for 1db. Paul has such a big hand that he cannot finely control the volume knob for 15degrees at a time for 30 degrees at a time? Another data point, we have used the same volume control for 6 years and I have not heard anyone complaining about the volume control. What is more, I have not had a single customer returning our product because the volume control is lousy. So what he did was he had to adjust a large angle to make a difference and yet it still does not sound right with a different material.
Second, the limiter is to compress the output. Why would Paul notice a volume suddenly jumped? That is the opposite of compression, isn't it? Has he noticed the sound level being compressed before he observed the sound level jumped. Has he set the volume so high that he essentially keep the limiter triggering over and over again? If I want to describe a limiter effect, I would have described it as the volume seemed to sound like compressed and then expanded. He missed the first crucial clue of limiter in action. It is like hearing a sequence of A->B->C. A is normal, and B is compressed and C is recovery. Note the at C will never sound louder than A. That is the key.
This is like CSI. We are trying to figure out what he really has heard. Was he still in the loop of poor integration and observed the sound as weak at certain frequencies and overpowering at others. Was the jump in volume due to signal shifting in frequency, moving from null point to peak point?
My main point was there were contradiction or comments not making sense. When that happens, say in a legal trial, the whole argument will be thrown out, period because we cannot tell which is right or wrong. If that is true, what Paul had said should be not brought up over and over again.
