Marantz Sr7011 volume almost all the way up
doum121
An alternative:
Just go into your "setup menu" and select "INPUTS">"SOURCE LEVEL" and change both your "ANALOG INPUTS" and "DIGITAL INPUTS" to +12.
This will allow your volume to read -12 when you are getting the 85dB SPL.
PS: There is no good reason not to just leave the Input levels as they are and just turn the volume up. The control will top out at +18dB, but that is 103dB. If you follow the instructions above, +18dB setting would equate to 115dB.
PS2: My directions above are based on the Denon 4520. Your Marantz is similar, but I'm not certain the menus are labeled exactly the same.
Ahh ! I do now ( finally ) understand . Thanks for your patience and help to all of you . I will look further into tweeking it now that I understand the 85dB at reference.. Understanding makes it way more enjoyable.
have a good day.
It's really simple.
Just go to Speaker Manual Setup and change all the Speaker Channel Levels to the following:
Front L +3.0dB
Front R +3.0dB
Center +4.0dB
Surround L +2dB
Surround R +2dB
Surr Back L +3dB
Surr Back R +3dB
Then let us know if you still have to turn the volume up way too high.
It's really simple.
Front L +3.0dB
Front R +3.0dB
Center +4.0dB
Surround L +2dB
Surround R +2dB
Surr Back L +3dB
Surr Back R +3dB
Don't you want to know the levels of each channel as set by Audyssey first?
@PENG Assumed the OP posting this (post #30) was based on Audyssey:
Front L 8.4Ft -3.0dB
Front R 8.4Ft -3.0dB
Center 7.8Ft -3.5dB
Surround L 5Ft -4dB
Surround R 5 Ft -4dB
Surr Back L 7Ft -3dB
Surr Back R 7 ft -3dB
Don't know why ADTG did the center a bit differently, tho :)
Center 7.8Ft -3.5dB
Surround L 5Ft -4dB
Thanks, don't know how I missed that..
Center 7.8Ft -3.5dB
Surround L 5Ft -4dB
Well, it's only a +0.5dB difference. I rounded up the center. :D
