Thank you for the fantastic review Clint! I've owned this receiver since 12/07 (a Christmas present to myself) and I've been really pleased with it. It's great to see reviews, especially positive ones, start to come out. Coincidently, I just finished reading another review in this months Sound and Vision magazine.
A few points:
Did you experience the -9db sub woofer level bug after running Audyssey? After I ran the Audyssey set-up, I noticed that the bass response seemed exceptionally weak. I snooped around AVS forum and found others were experiencing the same issue. There is apparently some math error going on but it's easily corrected by manually bumping the trim of your sub up by 9db. I did that and boy what difference - sounds great!
In regards to the HDMI 4/1/1 issue, not to make excuses but could it be that there is some sort of HDCP or other copyright protection whohah going on here? I don't know, just speculating. It's not an issue for me in my configuration - I have a plasma display for daytime and a front projector for nighttime viewing in the same room. At night my screen comes down in front of my plasma, I switch the projector on and switch the HDMI output to #2 on the 7002, using my Marantz remote. Not a problem for me but I guess it could be for users with displays in two separate rooms. Then again, isn't that what D/A's and splitters are for?
Finally, the reference in your review to the Apollo/Saturn V Visitor Center soundtrack gave me a big smile. I was also involved with that project (special effects) and now you've gone and made me want to dust off my copy of that CD and give it a spin!
