Yes buying brand new speakers would most definetly solve my problems, but if I wanted new speakers I would have just bought them in the first place. At this juncture I've broken nothing yet, so I'm not ready to give up, not until something is set aflame. Also I don't have other speakers just kicking around, besides bass/guitar amps, so it's these of the tv built in speakers
The speakers measure 3.5 and 3.6 Ohms, I am ashamed I didn't measure that before i ever hooked them up, as I get a little gung-ho from time to time.
I will have time tonight to take the woofers out and check all the connections again and have a look at the crossovers. Though without taking the circuit apart how would I test it? I don't think my meter is capable of measuring the capacitors
No you can't test caps with a multimeter. The DC resistance you measured is about where it should be, for 4 ohm speakers.
If the caps are non polarized electrolytic types they need replacing anyway.
Replace them with polypropylene caps of the same value. In my view electrolytic caps don't belong in passive crossovers. My designs never use them, never have and never will. Unfortunately they abound in speakers these days, more than on the days of old. All to meet price points in this money grubbing age.
If your receiver will not drive them after cap replacement, then they need a different source of power.
Unfortunately receivers are a necessary evil to get to those dreaded price points. However any receiver not on the $2000 dollar level, is going to reduce output significantly into four ohm loads. Receivers under the top end price brackets, will give no more than half their rated power into four ohms. If the phase angles of the speaker are adverse (common), then people who think they bought a 100 watt per channel actually only bought a 30 watt per channel receiver under what could easily be their condition of use.
Fortunately halving the power available to a speaker from 100 to 50 watts only reduces spl 3 db. That is how they are able to get away with it and the public none the wiser.
I still maintain, that if funds permit going with a pre amp and separate amplification is a big upgrade, with a decent separate amp.
No one will ever convince me that amps belong alongside the high gain stages and processing circuitry. In fact the optimal place for amps is in the speaker, and that is what we should move towards.
And to the cowardly pleb who gave me the red chicklet yesterday, for my honest opinion about receiver, identify yourself and let an honest debate begin. You can delude yourself all you want, but it will not change the facts.
